Question about HP (176135-630) (176135630) Internal 48x CD-ROM Drive
Cd and dvd do not work
Have a HP Pavillion a620 n and neither my cd or dvd are working. Went into Device manager and clicked on dvd/cd drives and it showed lite-on-dvd+rw sohw-8025 for my E:\ drive and Samsug cd rom sc-148 A for my F:\ drive. It said that both were working Correctly.
Then went into My computer and right clicked on each drive seperately then clicked on drivers and it showed W DC WD 1600jb-00G0 for both drives . It did show the actual drives but when I clcked on them the apply button did not work. How do I get the correct drivers to work?
  • HP Master
  • 2,007 Answers
  1. what OS? XP? if yes, is SP3 installed? XP has big troubles with dc/dvd or BRD drives. so, say what OS first.
  2. driver must match OS, so....
  3. what media are you attempting to read, CD, DVD, Blueray
  4. is said media, (real) or is it record-able , like CD-r or DVD-R
  5. we have idea what you have there , only a620 old.
Posted on May 07, 2017
  • 208 Answers
SOURCE: cd-dw drive corrup or file missing
use filtercheck 4.6 in forums to remove upper and lower filters.
Posted on Nov 16, 2008
  • 461 Answers
SOURCE: cd/dvd rom not working on hp laptop
Is the Drive detected in the BIOS? Can you boot from your Windows or any bootable disc? If so try this solution:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
Quit Registry Editor.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Posted on Dec 17, 2008
SOURCE: hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
Posted on May 27, 2009
  • 358 Answers
SOURCE: hp cd rom dvd drive
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit, then boot your system properly again.Then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Posted on Jul 20, 2009
  • 102 Answers
SOURCE: HP pavillion DV6500 CD/DVD RW not responding
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Posted on Oct 10, 2009
Solution for error 0xEB020BE2
That means the DVD cannot burn anything without fatal errors.
Locate your CD drive in the Device Manager list under DVD/CD-ROM. Right click on the drive and click Update driver. You may need to uninstall the current driver first and restart the computer; this is in the same list.
Jan 30, 2014 | HP Pavillion ZV6000 Notebook
My hp pavillion dv6000 dvd is not working when i ckeck it on the device manager it was not there what should i do
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 04, 2011 | Pioneer DVR-107D DVD±RW Burner
Unlock the region on HP Pavillion dv6-2111TcX with bluray
Go to control panel /system / hardware tab , then click on device manager then find your dvd/cd drive right click on that and select properties. there should be several tabs the one you want will be named dvd region or something like that.
some drives will only let you change the region a couple of times
Jul 25, 2010 | HP Computers & Internet
The dvd/cdrom drive on my pavillion laptop is not
go to start -> run here in the run box write devmgmt.msc This will lead to device manager here in disk drives or sata-ata remove ur cdrom driver by right clicking it and choose uninstall. This will uninstall the drivers for cdrom and now at the top where ur computer name displayed right click on it and select scan for hardware changes. It will automatically install drivers for it.
May 06, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My hp pavillion dv6000 dvd burner is not working when i check it on the device manager it was not there what should i do
download the drivers for this unit from manufactuers website and install them,then check your device manager again
Apr 27, 2010 | Pioneer DVR-107D DVD±RW Burner
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
Hp pavillion dv9000- cd/dvd rw drive not working
May 10, 2009 | HP Pavillion DV9060US Notebook
Cd/dvd drive not appearing
is there power and what kind of connection? did you install it with the add hardware wizzard?....if you did can you see it in device manager and does it show it is working in the device manager... if yes try reinstalling the drivers just click properties... if that doesnt solve the problemma re-check your cables...
Mar 09, 2009 | HP Pavilion dv6000z Notebook
Gud morning, I my dvd desappered. I cant load any cd. the iocon is not showning. how do i rectify this. I am using HP Pavillion dv6700. my dvd device is "pioneer dvd rw dvr-k17b ata device". Please i need...
ok first of all has anything vhanged, there is a known problem when upgrading XP to vista, where te cdrom.sys rivers arent installed. this is fixable but tedious, if it just simply dissapeared without change, go to device manager:
XP: START> RIGHT click my computer > click "properties" > "Hardware" tab > click the "device manager" button.
VISTA: START> RIGHT click my computer > click "properties" > on the left click "device manager"
under DVD/CD-ROM drvices, you should see your dvd drive, now the field is probably expanded already and it most probably has a yellow exclamation mark next to the device, or it has a large yellow question mark. this means the driver for the vd rive has either failed or is not working properly.
quick fix for this is to simply RIGHT click on the device, click uninstall, confirm, and once un-installed, re-start the machine. apon restart windows should automatically detect the dvd drive as a new device and install it.
if there is simply no device listed under DVD/CD-ROM devices, or the catergory isnt there, windows isnt detecting it at all, which commonly means the dvd drive itself has failed, (the fact it may be powered and opens/closes is irrelevant). but before throwing it away, try changing the IDE/SATA cable. if the uninstall/re-install doesnt work, you may need to re-install it from a winows disk, which is a little tricky. but can be done. let me know if it doesnt work and i will pace you through it.
Jan 02, 2009 | Pioneer DVR-107D DVD±RW Burner
My drive plays DVD's but will not read CD-ROM ? it did at one time is this a setting error
DVD and CD require different spec lasers (DVD requires 1.3nm compared to 2.1nm for CD)
It seems like your CD laser is broken, although your DVD laser still works. Replace the drive, it's not too expensive.
Apr 12, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
HP (176135-630) (176135630) Internal 48x CD-ROM Drive Logo
125 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
