Question about Freeplay Energy S360 AM/FM/SW/DAB Radio
No sound from speaker
Bought the radio a long time ago but only now opened it up. Did the wind-up routine. Put it in the sun. I thought it was broken. Absolutely no sound from the speaker. Finally, I plugged in a headset and it works okay. Is there anything I can do to fix the volume control? Can it be fixed?
  • 215 Answers
If the volume is adjusted when the headphones are plugged in I'd be looking at the speaker. It may need replacing. I don't know if the headphones are run from a preamp or attenuated via the audio output IC. If it's run from the preamp then the main output could be kaput. Check the speaker and it's wiring first and go from there.
Posted on Jul 22, 2006
2004 honda accord radio
An issue I had with my radio was the sound not working. Some wires were touching metal this causes the sound to not work. In addition to this make sure the antenna cable is hooked up!
Jan 24, 2014 | Cars & Trucks
Meter shows good send & receive strength but no sound from internal or Aux. speaker.
If mic is ruled out (broken connections etc) likely a cap in the audio circuit has opened--this happens a lot when a radio is stored for a long period of time.
Going to need a schematic and a meter to test the caps in the audio circuit--could also be a bad audio chip or connections at it.
SD TECH
Apr 21, 2012 | Radio Communications
My radio worked when I bought my truck but now it turns on but will not play any sound to the speakers
Park your truck in a silent place (best time to do at night) ask someone to get close to any speaker and in a silent place and turn on the radio. When turning on there should a slight "click" sound in the speaker. If there is a click sound then tune to other radio station and try if still no sound then there is a problem with your receiver circuit. If there was no click sound then either:
Your radio amp circuit is gone or
Wire connecting speaker are broken
You can trace the broken wire by physically checking the wire from speaker to head unit, if its fine then your radio needs repair.
Jun 09, 2011 | Pioneer Premier DEH-P410UB Car CD/ MP3...
Put the radio in my truck about 4 months ago, worked great. the truck sat for months because it was broke, now i get it fixed, put the face on my radio and everything is on, my radio, my amp is running but...
Turn the volume up to the highest level.
Can you hear a hiss or static?
NO...usually means speakers are disconnected..often loose socket at rear of radio or broken wiring
YES...Hiss means either blown speaker, faulty radio or faulty aerial.
If you have tape or CD as well , this will prove whether it is the aerial or not.
HISS with CD or tape playing means faulty radio or speakers
WORKING OK with CD or tape means faulty aerial
Feb 20, 2011 | Car Audio & Video
06 ultra radio no sound from speakers only headset.
Switch is fine. You have a damaged audio circuit caused by vibration. Check the bikes mounting brackets. probably broken. The radio will need to be repaired. www.ironcrossaudio.com
Apr 21, 2009 | Harley Davidson 426290 AM/FM Radio
My radio is on, but no sound comes out
speaker wires loose or faulty check connections;possable speaker plug behind radio loose.adrian
Feb 16, 2009 | 2003 Cadillac CTS
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
1996 gmc suburban factory speakers
sounds like you have a wiring problem.....
May 08, 2008 | Car Audio & Video
Crank problem
the drive mechanism has failed. try this. ensure it is fully unwound. then open it. then look for some part of the drive gears or belt that has broken or has slipped off. caution, you MUST ensure it is fully unwound prior to opening it.
Jun 03, 2007 | Freeplay Energy Plus AM/FM/SW Radio
Freeplay Energy S360 AM/FM/SW/DAB Radio Logo
193 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
RudeRude
John In Milford
John In Milford
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
