Question about Itochu C.itoh CI 5000 Matrix Printer
Paper feed issue on C.Itoh ci 5000
It is a C.Itoh dot matrix CI 5000. Using tractor feed. When advancing the paper using the knob, paper tractor slips. Tracked it down to a gear on the platten that advances the tractor. I can manually push the platen assembly to the right about 1/8" and works ok. I assume that gear is either worn (doesn't look like it) of out of align (can't find any way to adjust). Any assistance is greatfull.
2 Suggested Answers
  • 93 Answers
SOURCE: SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
Posted on May 19, 2009
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Need the XP driver for the citoh ci-5000. Was working well on old computer... it died, I connected it to another computer and I can't find the driver... please help, I need this asap THANKS Will
copy past this downbelow in your browser pick os
http://citizeneurope.com/drivers/dotmat.htm
Oct 06, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Printer head damage the printer ribbon
See if there is a pin sticking out of the print head. If so, you must replace the head. You can google and find a head.
Aug 04, 2009 | Itochu C.itoh CI 5000 Matrix Printer
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
hi
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
Error code A21
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
Aug 30, 2007 | Itochu C.itoh CI 5000 Matrix Printer
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Home Error
Apr 02, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
57 people viewed this question
Top Itochu Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
