Question about Apple iPOD 20GB Toshiba Harddrive for Gen 1, 2, 3 & 4 iPODs - MK2004GAL (Refurbished) (IP1930) Hard Drive
Ipod gen3 nano
Hi there please help me if you can went 2 charge my ipod and it froze i went 2 disconnect the charger thinking everything is good once i disconnected it on the screen it still says connected and on the left hand corner its got the lock symbol i have unlocked it with the button underneath but the lock symbol still shows dont know what 2 do please help if you can many thanks m3kee
  • Apple Master
  • 13,433 Answers
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
see this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Posted on Oct 21, 2008
7th generation iPod nano won't hold a decent charge.
Hi Sarah!
It is actually a common problem with devices that feature rechargeable batteries. The solution is to condition your battery. Once it is showing a 100% charge, disconnect and do not charge it again until the iPod completely shuts off and will not turn back on. Plug it back up to the charger and repeat. This will condition the battery to "know" when it is full and when it is not. Leaving it charging all day conditions the battery into "thinking" that it must stay charging or it is empty.
Hope it helps!
Dec 09, 2013 | Apple iPod classic 7th Generation
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
Aug 05, 2013 | Apple A1199 ipod nano
Won't turn on
Is your iPod fully charged? Sometimes the batteries become so depleted of charge that an accessory charger won't turn it on.
-Try plugging it in to your computer or a wall charger for a while, time will vary but it may turn on.
-If it is not turning on your computer will never recognize it, thus you won't be able to do a restore with iTunes.
-Try a hard restart as well this could help you.
Sep 02, 2010 | Apple iPod nano 4th Generation
I have the white screen on my ipod nano 2nd gen i tried the reboot, restore, debug everything i cant see any logos text or anything i cracked my old screen ao i bought this put it in and bam white screen...
Hi.
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod. Try these steps:
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes
Nov 05, 2009 | Apple iPod nano 2nd Generation MP3 Player
My Ipod froze
You can usually reset a frozen iPod by holding down the menu and center buttons for about 10 seconds. Hope this helps!
Jun 23, 2009 | Apple iPod nano
My ipod nano does not want to turn on at all its dead i charge it and it turns on but now it doesnt and when i connect it to the dock or cord it makes a static noise but still of
i will help you if you help me i have almost the same problem my problem is i turned it on it was good i connected it to my computer and it froze??? email me at sheran_osmani@yahoo.com if you dont have a email make one some how!(:
Apr 05, 2008 | Apple iPod nano
Apple ipod nano blue 4gp
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 16, 2008 | Apple iPod nano
Ipod 8 gb nano froze
Plug it into your computer and use the link in itunes to restore your ipod. This will usually work. If it doesn't, then it is time to contact Apple support to cover your warranty, or take it back to the store.
Mar 05, 2008 | Apple iPod nano 3rd Generation
Ipod nano is not regonized by pc.
You better check the iPod Data cable once again and be sure the PC which you are using should have a USB Port Version 2 (USB2) older USB was coming USB1.1
Feb 27, 2008 | Apple iPod nano
Apple iPOD 20GB Toshiba Harddrive for Gen 1, 2, 3 & 4 iPODs - MK2004GAL (Refurbished) (IP1930) Hard Drive Logo
760 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
