Question about Kenmore 24 in. 15689 Built-in Dishwasher
Soap problems Not only won't the soap dissolve but there are granules on the inside of my glasses. The dishes are also not getting very clean. I have been using cascade 2 in 1 action packs for a few months now with no problem, they've been great. I ran a wash 2 days ago and when it was done, I opened it up and the dishes were still dirty and the action pack was just sitting there slightly open with detergent sitting on the bottom of the machine. I had done a wash 2 days before with no problem. I have ran it 2 more times with no luck. can water hardness change that quick or is there another problem? Thanks for your help.
  • jsduch Dec 07, 2008
    I had the same problem. In addition, after purchasing new glasses when I placed them in the dishwasher to be cleaned for the first time they came out with dirt on them. They were placed in brand new and clean they just needed sanitized. I think these are two seperate issues but both are very annoying. I was told by the soap manufacturer to place the soap packets in the silverware basket or on the bottom of the dishwasher. It seems to help with dissolving the packets but the residue issue still persists.
  • 375 Answers
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some (quite some) water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 11, 2010
sclarke7
  • 218 Answers
SOURCE: detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Posted on Aug 27, 2009
catriver
  • 878 Answers
SOURCE: detergent is not completely dissolving
brotha, there is a couple service flashes out there that affect your model. They have to do with poor washability, redesign of the upper spray arm and top spinner. This could be your problem with the spray arms not hitting the soap dispenser properly. You would want to call Sears, I think you would be covered under these service flashes. Other things to check would be water temp. It should be at least 120 degrees entering the dishwasher. If the chopper screen is clogged with gunk, this would prevent a good flow of water to the upper spray arms as well. Catriver...post back.
Posted on Mar 27, 2007
ghappliances
  • 126 Answers
SOURCE: soap problems
PLEASE TELL ME WHAT TYPE OF SOAP YOU ARE USING AS WELL AS RINSE AID.NEED MORE DETAIL TO ASSIST YOU.
MOHAMED
Posted on Sep 19, 2008
  • 108 Answers
SOURCE: the detergent dispenser opens but the cascade
Maybe that is a bit much... I thought of something else you might check... there is a screen at the bottom of the dishwasher... make sure it is clean so that water can keep recirculating.
The thing about adding water is that if you add the water at the beginning, it is going to circulate for 3 minutes or so and then dump out the water and attempt to refill. Most machines do a couple "rinse off" cycles before the soap dispenser opens and the machine washes the dishes for a long time. So you have to put the water in after you hear the dispenser "pop" open.
I'm not completely sure about the Kitchen Aid, but their might be a way to adjust the time that the water inlet valve stays open at the beginning of the cycle... you'll have to check your manual.
Posted on Jul 28, 2009
  • 523 Answers
SOURCE: Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
Posted on Jun 01, 2010
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
Soap is left on the dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 25, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 18, 2009 | Maytag Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap problems
MOHAMED
Sep 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
6. Smoky film on dishes and glasses
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
228 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
