Question about Packard Bell Easy One Silver 2120 Notebook
Packard Bell Easynote MZ36-U-024-UK
Computer appears locked up by previous owner, the seller. At startup I have a press F2 or F12 to enter multiboot. I do neither and it prompts for a password. I assume this is set by owner but have different explanations. I intend to open her up and remove CMOS battery. If all else fails I resell on eBay and cut my losses. Packard Bell do not respond to help. I am desktop savvy but laptops are not my game. Opening it seems to be a hurlde to cross. Help very much appreciated.
Regards
Andrew
  • Packard Bell Master
  • 5,568 Answers
Just removing the battery briefly may not reset CMOS. Look for jumpers near the battery clip and if there are some, remove the battery, short any jumpers nearby. Failing jumpers, I would suggest leaving it without battery for at least a day; some are using 'supercapacitors' and a battery.
Opening a laptop case can be daunting; be advised that after you have removed any screws from the under- & back-side, the mating plastic parts may still have molded parts that will need to be popped apart. If the slits between the mating parts will accommodate it, an old credit card will sometimes avoid damage to the plastic, otherwise a putty (or spackle) knife will work.
Make sure you are not carrying any static charge before poking around inside; it can be a killer. Touch any exposed sheet metal or a heatsink to equalize any charge.
Posted on Dec 15, 2008
My Packard bell tj65 won't show toolbar
May be OS miss. You can unplug your RAM and then plug it again then try it again. If it display same thing then recover your operating system from system reboot system.
Thank you
Sep 07, 2016 | Packard Bell Easynote Tj61 Windows 7 Hdmi...
How to restore packard bell easynote se to factory settings
There should be a menu when you press f7 or f9 during bootup (or f2 for some brands) when you access that menu, you should see an option to reaet your device back to factory settings
Feb 13, 2013 | Computers & Internet
Packard bell e1245 crash
try press f5 when system is starting up then go safe mode, then try to restore your system to earlier setting with system restore. system restore is located on start/accesories/systemtools/system restore.
Mar 05, 2009 | Packard Bell Easy One Silver 2120 Notebook
Packard bell easy note
you've went in 2 bios and if your not clued up on how 2 set up bios refer to your nearest computer shop 4 advice
Jan 14, 2009 | Computers & Internet
Packard Bell Easynote MZ36 24 uk
You could search the internet for Bios Master passwords. Other than that, just pull the ac power, main battery and cmos battery and let the system drain.
If its a Windows password, then respond back for more instructions.
Oct 23, 2008 | Packard Bell Easy One Silver 2120 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Packard Bell Easynote M5255 - Will not boot up
option f2, go into bios setup and see if the hard drive is listed or detected. Auto detect hard drive save and exit. System will reboot if the same error occurs then the hard drive master boot record is probably corrupt or the hard drive has totally failed.
Apr 19, 2008 | Computers & Internet
Easynote mv35-202 locked at f2 screen
you have to set the hard drive first if there is any one detected if not there is bad hard drive and you have to replace it
Jan 02, 2008 | Packard Bell iMedia SL 9553 (P660401806)...
Packard Bell Easy One Silver 2120 Notebook Logo
748 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
