Question about Canon PIXMA MP160 All-In-One InkJet Printer
Cannon Pixma 160 - How do I reset the ink level indicator
Recently purchased new ink cartridges for my Cannon Pixma 160 but the ink level indicators still display "ink levels low" plus warning LED's for both Black & Colour cartridges ???
Previous ink cartridge replacements have been ok.
I can still print ok but warning message appears with every print job.
How do I reset the ink level indicators ?
  • 4 more comments
  • Anonymous Jan 23, 2009
    I have a Canon MP 160 printer. i put in a new color and black cart and the display still shows low ink and the light next to black is blinking and the light next to color is on stedy. How do I reset the display? Thanks
  • Anonymous Mar 13, 2014
    black ink doesn't print
  • Anonymous Mar 15, 2014
    I replaced both ink cartridges and the printer says that I am still out of ink and will not print or give me options to reset or over ride
  • Anonymous Mar 19, 2014
    no ink level
    will not power back on after trying to reset ink buttons
  • Anonymous Mar 22, 2014
    will not print
Crapt the driver
Posted on Oct 21, 2008
How to reset mp630
Hi
auto-reset chips reset when ink cartridge is removed and replaced, but only if ink level display indicates 'ink out' already. Any other time the ink levels stay the same.
Jun 07, 2014 | Canon Auto Reset Chips For Pixma Mp550...
I changed ink cartriges and it won't let me print it says ink is empty. How do you reset the ink levels?
There is no reset for ink levels. When you open the cover do the cartridge lights flash indicating the cartridge is empty. This problem can arise from using compatable cartridges. Try a set of genuine cartridges and the problem will probably be solved.
May 04, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Error occurred 6000
It's an ink level indication.
If you are using re-filled ink cartridges, try this.
To solve the ink level error in canon Pixma iP1800/Canon Pixma iP1880. This problem usually appear after refilled the cartridge on the canon printer and ink level indicator showing the ink cartridge is empty although you have filled a cc Ink into the cartridge. And if the problem occur you cannot using your printer to print. The solution you must reset ink level on the printer if you want your computer work again.
If you have a problem like that you ca follow this tutorial to solve your printer problem, here how:
Turn of the printer and Disconnect the power cable to the printer.
Press power button on the printer. While pressing the button connect the power cable to the power source (the power indicator will light in green)
While still holding power button press resume button twice - orange blink and return to green.
Release the power button, then the PC will recognize new cartridge installed (If the power indicator on the printer steady in green you continue to Steps 5)
Run the IPtools software, please await after this software detect your printer correctly or you can set the printer model on "Change Model" section.
Click "reset black and reset color" button to reset the ink level and Click "reset main and reset platen" to reset waste ink counter. After clicked the button you will see ink level of the cartridge on in the IPTol info has 100% and WP and WM has set to 0. Click Exit on IPTool
Turn off the printer and turn on again.
On the reset procedure above usually the problem found on steps 1-4 to make the printer steady light in green. On my experiment if steps 1-4 does not work on your printer, you can use manual reset method for canon iP1700 before continue to steps 5.
Good luck
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Error u043 with MP610 Cannon. cyan cartridge not recognised, tried new cartridges, same error. RESET DOES NOT FIX PROBLEM
This error indicate that the printer fail in detection the certain ink. The simplest one is to compare the ink tank with the good one. If this doesn't fix the problem,carriage unit or logic board might be faulty.
More information
Nov 29, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I cannot get printer to recognize new or refilled cartridges. How do I reset Cannon MX310 to see new cartridges?
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
If you put a new cartridges the printer will recognize it automatically.
Oct 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Nov 27, 2008 | Canon Office Equipment & Supplies
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
2,040 people viewed this question
old marine
old marine
