Question about Dishwashers
Faulty Diplomat Dishwasher - tripping mains fuse
Hi
I have had above integrated dishwasher which is intermittently tripping the mains fuse.
Power is getting to dishwasher and the washing cycles work until a certain point (not the same time) where a loud bang can be heard and the main fuse is tripped. Reset the main fuse and power still gets to the dishwasher and it works again.
It has just started to trip the fuse when its not running any cycle (just when power is getting to it).
I've checked the fuse on the spur and it looks ok. I have yet to move the dishwasher out as its integrated but wondered if anyone had any ideas before I call out a plumber!!
Tks
Barry
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Posted on Jan 09, 2009
Why isnt my dishwasher powering up
assuming the power circuit breaker is ok and you are getting power to the dishwasher itself, there are other factors that could lead to an outcome of dishwasher not appearing to be powering up.
The most likely cause is power supply inside dishwasher is faulty, the controller is faulty or simply the dishwasher display panel is faulty.
More likely the dishwasher has suffered a "thermal" trip. The thermal fuse located in the control panel on the door has blown. You may need to replace it. It is item 6 on this diagram
Jan 04, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
Samsung dishwasher wont run; delicate cycle light blinking
see this causes and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
5( test the main board can be faulty and replace.
Oct 02, 2012 | Samsung DMT400RHS Dishwashers : Built in...
My dishwasher seems to not be getting any power and no lights are lighting up. It is still plugged in and I already tried resetting breaker. Any suggestions?
HI. Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything checks out ok with the above suggestion, the main control sector(timer or control board), will be the culprit.
The control sector must be replaced, in this case.
Dec 11, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
MAINS ELECTRICITY FUSE TRIPS WHEN DISHWASHER TURNED ON
Hi, I think you will need to check the heater or the wash pump, as these are the first things to energised. IOf yo could give me some more information then i could tell you where to after these things have been tested ok!
Get back to me......
Jan 10, 2009 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Nov 15, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
1,200 people viewed this question
Top Dishwashers Experts
