Question about Gaggenau GI936-760 Dishwasher
Gaggenau BS220/221-110 STEAM OVEN and BO 220/221-110 OVEN fixing
I have just bought these two ovens and I cannot work out how to fix them to the Kitchen carcass. Screw holes are present on both but the door on both seems to be in the way.....so you would think the door would have to be removed but I cannot work out how to do this.....any suggestions?
n.b they are both side opening doors with massive steel hinges.
Gaggenau steam & microwave ovens are only fixed on one side depending on door hinging ( theory is that they are so heavy that that is all that is necessary) & that is from the Gaggenau technical department.
Posted on Jul 11, 2009
I bought a 220 Gaggenau steam oven and it was at a show room, it will start right. Solove this problem please.
Posted on Nov 19, 2008
Gaggenau oven display clock unreadable.
The display may have to be replaced
Sep 01, 2016 | Gaggenau Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
F 71?
Der Abfluss dürfte verfstopft sein. Bei mir war es am Ende des Schlauches hin zum Siphon (Fettablagerung durch die Spülmaschine). Für den Handwerker von GAGGENAU habe ich dann 170,- Pauschale für 10 Min. gezahlt...
Probably the drain is blocked. The blockage was in my case at the end of the hose. Finally I paid 170,- Euro for the GAGGENAU handcrafter (10 Min.)...
May 23, 2010 | Gaggenau ED 220/221 Electric Single Oven
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
My Gaggenau oven shows a F-40 code with the key symbol flashing. Can this be reset in any manner?
I have the same problem and the technician came out and took the oven out. He couldn't figure out was wrong and will need to contact the manufacturer technician to help him with the diagnosis of the problem. In the meantime, he says it looks like my modem is not working and may not be responding to the commands that would normally remove the key lock after a power outage.
Sorry, can't be reset - you'll need to pay the big bucks to have a technician out to assess, make sure you tell him your model number so that he can do his homework prior to coming out, that way you're not paying alot of money that I had to for this tech to figure things out. He took one hour and charged me $120 with no fix and will have to come back anyway.
Nov 16, 2009 | Gaggenau ED 220/221 Electric Single Oven
Error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Nov 03, 2009 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
Aug 27, 2017 | Gaggenau EB290/291 Oven
Single oven door latch is broken
hi we sell gaggenau parts but we are in the uk sales@gwhitedist.co.uk
May 04, 2008 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau GI936-760 Dishwasher Logo
573 people viewed this question
Top Gaggenau Dishwashers Experts
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
