Question about Kodak Ektagraphic III-E-Plus 35mm 140 Slides Rotary Carousel, 80 Slides Rotary Carousel Slide Projector
No reverse Projector will not reverse either with the remote or by the button. The mechanism functions with the reverse button but it advances instead of reversing.
  • 1,476 Answers
Your unit could have several problems. First you need to remove the bottom of the unit. Turn it upside down and unwind the power cord from the storage area. Remove the 6 star screws. Remove the bottom cover. Now you can access the cycle solenoid and lever. From this point on you will need to be very careful. Plug the unit in. Turn on and depress the forward button. Observe the cycle lever and how it works. It could be out of adjustment and not pulling the mechanism far enough in the reverse mode. If that is the case adjust the solenoid location so the lever pulls the mechanism further in reverse mode. If adjustment is not the problem check for dried grease on the cycle cam. Clean all the grease off with an electrical degreaser (do the adjustments and the degreasing with the power disconnected). The unit uses special grease (high temp) which comes from Kodak. You should be able to try it without grease to see if the problem is solved. If it is then you will need to get some grease part #TL2730. If you do not feel confident doing any of the procedures you will need to find a shop that can work on these units. Most people are not familiar with them as they are fairly old. Cost should not exceed $50 US. Good luck.
Posted on Jul 21, 2006
  • 60 Answers
Before you take it apart, try holding down on the reverse button for a second or two. The reverse cycle requires the button to be held down longer than the forward cycle. If the button is just pushed quickly, it will go forward instead of backwards.
CameraRepairs
Posted on Aug 11, 2008
Fix focusing on ektagraphic remote control
Ektagraphic III A did not have remote focus. Someone has probably substituted a remote from a higher functioning model on this projector. The forward / reverse functions on the supplied remote will continue to function correctly, but the focus buttons will not.
Good Luck !! Jim
May 20, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Kodak Ektagraphic AF-1 will not advance or reverse
If the select button functions correctly, Chances are the direction lever in the mechanism is bound up or the Direction Lever Spring is broken. If the Spring is broken or the Direction Lever is bound up, the Index Lever will go out straight when the Advance / Reverse buttons are pushed - instead of moving out straight , then moving forward or reverse at a 45 degree angle.
The Slide Change mechanism needs to be re-built. The bad news is this projector was manufactured from 1976 to 1984. Kodak scrapped the repair parts in the early 1990's. Your best bet is to find a repair shop that has a projector that they can salvage parts for your projector from.... Good Luck !!
Dec 26, 2013 | Kodak Office Equipment & Supplies
Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
Dec 15, 2011 | Kodak Office Equipment & Supplies
Projector works fine, but will not advance slides. Does nothing with remote or with forward/reverse buttons on projector.
Try a different tray (preferably a Kodak 80-slide tray). If it works, then the problem is a tray problem. If it makes no difference, check the "SELECT" function. If that works, then your projector requires an adjustment to the slide change mechanism. If it does not work, remove the tray and push the "REVERSE" button 4 or 5 times (this will clear a mechanism jam if one has occurred). If you still have nothing, then chances are that the slide change mechanism drive belt is broken or stretched. try the diagnostic things I suggested. If they are no help, I'm sorry to say you need the help of a factory-trained repair dealer. Good Luck !!
Jan 21, 2011 | Kodak ATS Ektagraphic Slide Projector
I bought a used Elmo TRV-35H 35mm projector. The camera works fine, but the tray only moves in reverse when I press the forward or reverse button. And after moving through a few slides it then moves...
Remember, mains voltages exist within the projector and thus the unit MUST be disconnected from the supply line whilst carrying out any servicing.
The reported fault sounds like sluggish operation of the advance/reverse mechanism. Lubricants used in the past tend to age and dry out so that the mechanism doesn't function correctly. IF YOU ARE CONFIDENT TO DO SO, remove the top of the unit and locate the slide mechanism. Carefully clean with cotton buds dipped in pure electronic cleaner and then re lubricate, using an oil dripper with the finest industrial sewing machine oil - emphasis is on a 'drip' of oil on the moving pivot points. Put the top back on and try again.
Problems with remote controllers are suually associated with tarnished contacts either in the hand unit or the projector. Once again, the contacts can be carefully cleaned and all should be well once more.
If you are using Kodak Carousel magazines, make sure you are using the correct magazine for your slides - cardboard or glass mounts. Don't mix slides in a magazine, as this can also cause problems.
Dec 13, 2010 | Elmo Projectors TRV-35H Slide Projector
Kodak Projector 760H. Carousel won't move forward or reverse. With remote or pressing the actual buttons.
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
Aug 29, 2010 | Office Equipment & Supplies
We have a Kodak Carousel 650A projector. (140 slide carousel) Cannot advance the slides using the remote or the select bar. Putting in the individual slides with the carousel off the select bar will eject...
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Jun 20, 2010 | Office Equipment & Supplies
Kodak 760H will not advance slides
If the projector neither advances or reverses, then most likely the problem is caused by the cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is plastic, and over time gets brittle & cracks, rendering the slide change mechanism non-functional.
If the projector cycles in Reverse and functions in Select, then chances are the projector just needs an adjustment of the cycle solenoid.
Either problem can be addressed by a factory-trained service dealer.
Jan 18, 2010 | Kodak Office Equipment & Supplies
Projector broke
Given the age of the projector, chances are the cause of the problem is a broken "Link". The "link" connects the cycle solenoid plunger to the slide change mechanism. The "link" is made of plastic, and over time it gets brittle & cracks, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair that requires dis-assembly & a service manual - - best left to a factory-trained repair dealer.
Apr 01, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Kodak Ektagraphic III-E-Plus 35mm 140 Slides Rotary Carousel, 80 Slides Rotary Carousel Slide Projector Logo
330 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
