Question about Samsung SGH-G800 Cellular Phone
Setting a tone for text messages
I have a sound file but can not work out how to set this sound file on my phone to go off when I recieve a text message. Can anyone help me please.
    Problem Solver:
  • 5 Answers
This is easy. I don't mean to sound arrogant, sorry. follow these instructions: press the menu button/ go to/in settings/ the first tab is phone profiles/ press select/ options/ edit/ you will see three tabs at the top right of the screen, the phone with a speaker tab is highlighted/ go right one to the txt mssge icon, enter message alert type and choose the melody option, press o.k/ go down one section to the "message alert tone, press the options key/ change/ use my alert tone, this opens your files/ press right once to select memory card and choose the folder with the melody you want to use in it/ when you've highlighted the melody press options/ select. Next scroll down the page for the volume settings/ select whatever. You have now chose the melody for txt mssges. finally press options save. Job done. I know this is what you wanted. Good luck. Trevor
Posted on Jan 12, 2009
How do i get sound to work for recieving text messages
Depends on the phone, but on iPhone there is a very small lever on the top left edge above the volume UP button.
You should also check Settings - Sounds - Text Messages
COMMENT below my name with make and model.
Aug 02, 2016 | Cell Phones
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
Aug 17, 2012 | Samsung SGH Cell Phones
How can i change my message tone on my samsung tocco lite
How do i change message tone on tocco ultra
Feb 20, 2010 | Lands Phones
Lg renoir phone - sound issue
You are in the right place but looking at the wrong option, if you scroll down on the Normal profile you will see a message tone option, if you are not hearing a tone at the moment then I suspect it will say "No Sound". Tab this option and select Existing sound, you will then be able to navigate through the sound files on your phone and choose one of the Default Sounds (from the folder by the same name) or an MP3 or other supported sound file you have added to your phone.
If that doesn't solve your problem then you may have a faulty phone.
You can change the sound you get when sound alert is switched on by going to Settings > Touch Settings > Touchscreen Effect and choosing a different sound from the Tone option. You can also change the volume of the tone of severity of touch vibration here.
Jul 27, 2009 | LG KC910 Renoir Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Text message tone volume, LG KP500, Cookie
Go to Profiles, and choose a Customized Profile. Rename it to whatever you prefer. In this profile you can select your ring tone, message tone, volume, etc. I only had to do this once, and everything worked perfectly!
Feb 11, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Motorola i530 text message notifications
u need to go in to your sound setting go on to message tone looks like its set on silent then u will be able to hear it when it goes off
Jan 14, 2008 | Motorola Mobility i530 Cellular Phone
Set a ringtone for a text message SYNC SGH-A707
you need to send the ones you have put on and send them to a different file on the phone i will have a look for the manuall for your phone when i find it i will talk you through it step by step but you need to move the files from where they are into the file you need them in hope this is some help its not the phone so dont worry about that i will find the manuall then i will post u back ok .......................................
Nov 15, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Text Message alert???
In order to use tones other than the presets for text messages, you have to put new .WAV files on your phone. Any 8bit .WAV file will work; just connect with ActiveSync and navigate to your /Windows directory on your phone, and place the files there. You will then be able to use them as text message alert tones.
Aug 29, 2007 | Audiovox PPC 6700
Recieving sms
You can go into sounds and set alert tone for txt message so it will souns a tone
Jul 17, 2007 | LG Shine KE970 Cellular Phone
Samsung SGH-G800 Cellular Phone Logo
130 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
