Question about Frigidaire Refrigerators
Water dispencer snaped off
freezer door
  • 750 Answers
Hello bakerboytartWelcome to Fixya,
You said, freezer door! ????????????????????????
Can you send me the Complete Model number and the year of the fridge?
1. What is exactly the matter ?
2. What you are looking for?
3. Or what you need me to tell you, or find for you?
I'm awaiting your response!
Huuum
Posted on Oct 21, 2008
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Can not get water from the dispencer, checked all the inlet valves and they are working. disconnected the water hose going to the dispencer and water will flow when the switch is activated at the door....
If I read you question right, you can disconnect the line at the bottom of the door and water will come out when you push the button but when you reconnect the line it will not come out of the dispenser. Right?
Simple answer... It is frozen in your door.
What I need to know is your serial#. I think it is the forth digit will be a 2 or a 4. If it is a 2, then there is a kit to keep it from freezing part# WR49X10173. When you look inside your freezer, you will have a steel liner( check with a magnet if not sure).
This kit will not work if it is a 4.. Do not try,it will not fit!
If it is a 4, then the only solution is to replace the door which is probably no longer available since ge is now owned by Haier :(
If it is a 4, you can defrost the door and see if it comes back. (unplugged,doors open for up to 24 hours but it will probably work within 6 hours or less) After defrosting, bump your freezer temp up a couple degrees and see if it comes back.
Feb 01, 2018 | GE GSS22JF Side by Side Refrigerator
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
Nov 27, 2008 | GE Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
