Question about Ricoh Office Equipment & Supplies
Ricoh 1075 with code C541 will not clear ,thermistors have been replaced
  • 76 Answers
You need to enter SP mode then turn the machine off and back on and it should clear the error as long as the parts have been replaced for new parts!
hope this works!
Posted on Oct 21, 2008
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
We have a Ricoh aficio 1075 with sc 541 and we already change the thermistor and reset the sc 541 but its coming back.... what should i need to do so the code can go away... let me know please>>>...
Hi.
Dear i advise you to-replace only Drum unit.
cuz i facing this problem so many time if isn't possible for you to change complete drum unit then change only drum. but if you want to check this problem just once time replace complete drum unit with drum don't fix previous drum.
and please don't wast ur time on heating unit :)
Best Regard's
Syed Babar Ali
Copier International Trading
Cell: +971556272142
Jun 21, 2011 | Ricoh Aficio 450 Copier
Error s c541
ERROR CODE C541
PROBLEM: Fusing thermistor open
the fusing temperature detected by the thermistor is below 7 celsius for 35 seconds.
POSSIBLE CASSES: The center thermistor non-contact or abnormal position
The thermistor open (you can check with Multi meter)
The thermistor connector defective
The thermistor damaged or warped
the fusing temperature -15% less than the standard input voltage
SOLUTION: you check very carefully if the thermistor is out of order then replace the thermistor with the same one and if you check heater unit and there parts lamp thermistor are ok then reset the heater code
press all clear (yellow key)
press (1) and (0) and (7) from key pad
press and hold 5 second clear stop key (red key)
enter service mode
then power OFF and then ON if the heater section is ok then machine get ready
Feb 10, 2011 | Ricoh Aficio 2035 Copier
Sc544 on ricoh 1075
You have a fuser error, you will need to repair the fuser unit or replace it, can be the thermistors, thermalfuse or heat lamp, then you'll need to reset the machine via service mode, strongly recommend to be repaired by a technician. Good luck.
Jan 06, 2011 | Ricoh Office Equipment & Supplies
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Reset code
Sp 1-902-001 set to 0. Let me know if this helps. -Carl
Jul 15, 2009 | Ricoh Aficio 450 Copier
Tengo una fotocopiadora ricoh aficio 1075 y me sale el aviso SC 541 que debo hacer para quitarle este codigo de error
Limpie o cambie si es necesario el thermistor de la unidad fusora, luego presione total clear key tecla amarilla, introduzca 107 y mantenga presionada la tecla clear stop tecla naranja, mas de tres segundos hasta que el tablero cambie a sertvicio, apague y encienda el interruptor principal y listo...
Buena suerte...
Jan 23, 2009 | Ricoh Aficio 450 Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
500's usually means overheating problem
contact service support from your local authorized dealer
Jan 10, 2008 | Ricoh Aficio 450 Copier
129 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
