Question about Samsung Digimax A503 Digital Camera
The camera turns off after i take a picture!
I have lost the maual to this camera! please help! sometimes the camera wil turn on and i get the samsung logo and then it goes off and other times it turns on lets me take a picture but every time i do it turns off!!
  • Samsung Master
  • 19,396 Answers
Here is the user manual : User’s Manual
Posted on Nov 06, 2008
I'm taking photos with my Samsung D860, and when I want to view the pictures taken, it says 'no image', 'file error' or 'card error'. Sometimes it also says 'card...
Actually the camera is fine and the cause of problem is memory card, Mostly cheaper cards do this but the original cards don't. And as far as concern that you have lost many precious pics, No need to worry about it. Just install any recovery software on your PC and with the help of the software you can get back your pics, Secondly, shift all your pics on memory card in your PC and then format the card through camera, this will solve your problem.(Remember that run recovery software before you format the card if you need to get back your data from memory card)
Thanks
May 13, 2011 | Cameras
My Sanyo VPC-S1414 wont turn on I dropped it in a sink while I was taking a picture, there was no water but it wont turn on and I dont have a maual for it,
Please, check it again for water inside camera while power off. Dry it out if found water. Check and download your manual at www.sanyo.com
Regards
Jan 09, 2011 | Sanyo Cameras
HI i have a canon ixus 700 it still take great pictures but when i try to use the flach on the camera it wil not take a picture please can you help
It's possible the camera is in one of the manual modes with the flash turned off. With the camera turned on and in the picture taking mode press the function button and look at the bottom of the screen. press the right or left side of the ring to highlite the auto setting then press the function button again.
Dec 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
My camera will not take pictures
Whats your camera make / model?
I have found this problem in the past mainly on samsung cameras. All I found was bad connections and poor solder joints.
connection problems with ribbons mainly. Samsung seem to prefer tinned ends as opposed to gold plated ribbon connections and these are just waiting to discolour and then fail.
Bad connections will drain batteries very fast and especially if your using cheap ones
Mar 15, 2009 | Cameras
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
How do I initialize a picture card?
Turn the camera viewer on (on your finepix 3800, it is the middle position where you preview photos). Press the "menu" button and you will be presented with four options, and the top option is FORMAT. Select format and your card will be usable again. Two things to keep in mind. Any pictures on the card will be lost, and when you press the menu button as I described it may take a few seconds before those four options appear. As an FYI, the most common cause of the card needing to be reformatted is when the pictures are loaded to a MAC computer and the USB cable is pulled before you eject the camera.
Nov 02, 2008 | Fuji FinePix 3800 Digital Camera
Camera
Make sure the battery is fully charged and just slide the front cover over
Aug 06, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Have a camcorder sc-d103 and night light stays on and has no picture
look for a small pinhole. insert a pin while powered up. this should reset the camera
May 26, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung Digimax A503 Digital Camera Logo
73 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
