Hp printer says cartridge error how to fix? - Office Equipment & Supplies
  • 31 Answers
Remove the ink cartridges and then place them back in the carriage. Powere off then back on the device.
Posted on Oct 21, 2008
I have hp cm 8050 printer showing error code D1.073B
follow this steps and fix it. God bless you
Instructions
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2Z7d9rxWS
Jul 15, 2013 | Office Equipment & Supplies
Error 3 massage comes in hp deskjet 1315 all in one printer
would to me what the error messages
If expired cartridges are present in printer, the printer will not be blocked but error message\light will be displayed to replace cartridge.
If expired cartridges are replaced with new ones the issue should be fixed.
Feb 27, 2013 | HP PSC 1315 All-In-One InkJet Printer
HP officejet error code 0x6101beb
If you get the Error code 0x6101beb on your printer, it's one of the common error occurs in Printer. In case this error is not fixed, it may lead your system slow or even it will crash the whole printer. Fixing the error code 0x6101beb manually is a difficult process so we suggest you can use any troubleshooting tools. In Some times, remove the cartridge from the printer and reinstall it, this will clear the error messages from your printer. Follow the given steps for troubleshooting the error code 0x6101beb,
1. Power on the printer and open the cartridge access door.
2.
If the cartridge comes the position, power off the printer and disconnect the cables.
3.
Remove the ink cartridge from the printer and leave it for 60 seconds.
4.
Then again insert the ink cartridge in their respective slots.
5.
Power it on and check if it clears the error.
Still, the error persists on your printer, better you can contact the printer experts through the toll-free number 1-800-386-3987 or 123.hp.com/oj4650.
Jan 20, 2012 | Office Equipment & Supplies
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP Office jet Pro 8500 wireless is not recognizing my ink cartridges. i have re inserted, changed cartridges, rebooted printer all to no avail. Help
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the printer cartridge check the following steps :
  • Turn on the lid of the printer and then remove the cartridge from the printer head.
  • Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
  • Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Sep 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP 4200 10.0000 supply memory error
It appears that the printer is having problems reading the e-label on the print cartridge. Remove and reinstall the print cartridge, then press the Select button. That should clear the problem.
Apr 07, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
How can I fix my HP Deskjet F4280 cartridge error message?
hi..i have similar problem with anjulyn80..i bought a new cartridge but still got a cartridge error in it..
Feb 18, 2009 | HP DeskJet 3740 InkJet Printer
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Cartridge error
cartridge error 4255 all in one hp officejet how can this be fixed ?
Jun 15, 2008 | HP OfficeJet 4255 All-In-One InkJet...
144 people viewed this question
jasbo
jasbo
