Question about Sony PlayStation 2 (PS2) Console
Play PS3 games using a externel hard disk
I hv a PS3 which have USB connections to it i wnt to knw wheather i cn install a game in to the external hard disk and play games using it.. Is it possible to do this way or gv me a idea to play games using a exteral hard connecting to the PS3.
Plz...
I think it was made for u to connect internet to the ps and play games online.thank you
Posted on Oct 22, 2008
Tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
on Feb 21, 2011 | Sony Playstation 3 (PS3) Console
How do you play copied ps3 games
You can, but it requires you to save the game on the hard drive in Fat32 format. I recomend checking out the videos on the PS3-P (portable) It should give you the info you need.
Sep 10, 2014 | Sony Playstation 3 (PS3) Console
My ps3's data got corrupted and it said i could restore it.i did, but now my online friends list is gone and so is my other data!please help me!
Unfortunately, if you did a full system restore without backing up your data, it's gone. Sorry, man. However, if you sign into your PSN account, you'll still have your trophies. I know it's not much. Sorry I couldn't be of more assistance.
Apr 16, 2011 | Sony Playstation 3 (PS3) Console
How was the msi on the 90's?
Go online to find experts that may guide you step by step.These menonline may show you how to fix your console just as an experienced repairmanwould fix it. Allthese errors can be fixed completely by you without the involvement of anyexternal agency. Disassembly 1.PS3 Disassembly 2. PS3 Controller Disassembly Fix Common Problems Fix to all update related problems 1. The Mystery of the Blinking PlayStation 3 2. The dirt on Blu-ray lens (and how to clean it) 3. PS3 Owners Report Blu-ray Problems After 1.5 Upgrade 4. PS3 Bluetooth Controller Issues 5. Playstation 3 HDMI Problem and Fix! 6. Display/Video Fixes 7. PS3 Error Codes (With related fix) 8. How to Change From HDMI > Composite Easier 9. PS3 3 Beep & Blinking Red Light Fix PS3 Modifications 1. PS3 3.5" SATA HDD Mod 2. Adding IR Remote Control to the Sony PS3 3. PS3 HDD Replacement Mini-Guide 4. USB Flash Memory, USB Hard Drive (External Use) Controller Modifications 1. PS3 Controller Light Mod 2. PS360: Microsoft Controller, Meet Sony Controller 3. PS3 Controller Light Mod 2 4. PS3 Controller Button Contacts, Add extra buttons to the PS3controller Other Modifications 1. Charging Station Headset Mod Blu-Ray 1. Decrypt Blu-Ray Movies with a PS3 WITHOUT keys 2. Blu-Ray Unique Volume Keys 3. Blu-Ray Media Links 4. Play BluRay movies without disk 5. Convert HD-DVD To Blu-ray (works On PS3), No Loss Of Quality Other Media/Video 1. Set up media servers for your PS3 2. Transfer files from PC to PS3 via WmP11/Nero (viaDLNA/MediaServers) 3. How to stream AVI files on PS3 via Tversity 4. Copy music/videos from your iPod to PS3 5. Getting your PS3 to recognize your External Hard Drive 6. How to create a PS3 HD-MPG from HD-TS (Best Result For Below 1.6FW) 7. How to install your game saves 8. Downloading PS3 Game Saves Audio 1. How to connect PS3 to PC speakers Networking 1. How to change from 'NAT type 3' to 'NAT type 2' 2. Make a Lag Switch 3. Who Needs SIMPLE DNS 4. Remote Play On-The-Go Playstation Network 1. PSN Game Sharing Instructions 2. How to download Japanese Demos/Create *** PSN account 3. Create Different Region PSN Accounts 4. View PS3 Store, Download Demos on your PC and install Demos To PS3 5. Play Online And Access Sony Store No Updating 6. View Playstation store on PC Firmware Modifications 1. PS3 Firmware Version Check Bypassed (Linux) 2. PS3 Firmware Version Check Bypassed (Windows) 3. Ettercap Windows 4. PS3 Demonstration Mode "Unlock" Code 5. Use SIMPLEDNS To Bypass The Firmware Check (Windows) 6. How to UPDATE your PS3 Linux 1. How to install Fedora Core 6 Linux for PS3 2. PS3 Linux - The void has been filled...Full install instructionsfor Fedora Core 5 3. PS3 Linux FAQ 4. GUI Kboot 5. Yellow Dog Linux Free Version 6. Yellow Dog Linux 5.0 Installation 7. Partitioning and readying your PS3 for Linux 8. Gentoo 9. Uninstalling Linux 10. Installing YDL+VLC+Mplayer+Snes9x 11. Installing Mplayer on PS3 12. Installing VLC player on PS3 13. Installing "Other OS" on PS3 14. How to get Wi-Fi to work with YDL 15. Set up a Linux UPnP media server w/PS3 support 16. Run Ubuntu Linux 7.04 (Feisty Fawn) on PS3 17. Ubuntu, Kubuntu, Xubuntu, and Edubuntu onto a PlayStation 3 18. Emulate WinXP in PS3 under Linux Downloads 1. Homebrew Loaders 2. Linux 3. Utilities 4. Firmware Updates 5. "Other OS" Bootable Homebrew 6. Drivers 7. Proof-Of-Concept Exploits 8. Game Saves PS2/PS1 on PS3 1. Do your PS2 games look too jaggy on the PS3? Here's a semi-fix... 2. PS3 SWAP to play PS2 and PSX Games! 3. How to play/install to play PS2 backups on PS3 Miscellaneous 1. PS3 Features 2. Finding RAM locations on resistance 3. PS3 Parental Controls How-to 5. PS3 BiOS Flash Diagram Rev 1.0 So,if you have experienced some of the errors in your console, it is not the endof your gaming days, you can fix it. There are many solutions out there if youare willing to do a little research. This guide most possibly willcontain the solution to the problem you have encountered.
Ps3 repair guide Goodluck, and happy gaming.
Feb 08, 2011 | MSI 1990 - 1996 for PlayStation 3
I want games free
Feb 08, 2011 | EA - Electronic Arts Need For Speed:...
I lost my biohazard4 game CD key.... Can u Post key to my email ID: balumahesh8055@gmail.com
Feb 05, 2011 | Capcom Resident Evil 5 for PlayStation 3
I have a slimline ps3 and my hard drive was corrupted so i downloaded a new system update it installed the update it let me adjust the time and date settings and just before it goes to the screen that...
  1. KINDLY REMOVE THE HARD DISK FROM THE CONSOLE
  2. LOOK FOR AN EXTERNAL HARD DRIVE PACK
  3. PUT THE PS3 HARD DISK INTO THE EXTERNAL HARD DISK PACK
  4. CONNECT IT TO YOU COMPUTER
  5. AND FORMAT IT.
  6. REMOVE IT FROM THE EXTERNAL PACK
  7. PUT IT BACK INTO THE PS3 CONSOLE AND TURN IT ON.
  8. IT WILL ASK FOR UPDATE
  9. THEN YOU UPDATE IT.
  10. IF AFTER DOING ALL THIS AND IT DOSEN'T WORK
  11. CHANGE THE HARD DISK INSIDE THE PS3.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
When we play ps3 and we try to change the options in the game the error 8003051E comes and the file does not save. even during the play the game cannot authomatic save. so everytime we need to start from...
HI,
Things You'll Need:
* PlayStation 3
* External hard drive
Unplug any external hard drive that may be attached to the PS3.
Restart the PS3, including unplugging it and plugging it into the power supply again.
Format the file you are trying to save to be less than 2 GB in size. The main reason you are getting this error (game will not save) is due to the large file you tried to save.
Connect the external hard drive to your PS3 again and save the file. The error should not occur again.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Upgrade of the hard drive
You cant really get a PS3 Hard Drive because Sony made their own Hard Drives so i think your gonna have to Contact them asking for a PS3 Hard Drive and i think you should really delete some Games like Demos you downloaded cause those Demos take up atleast 500 mbs each or more.
May 07, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
