Question about Casio EX-V8 Digital Camera
EX-V8 wont turn on
HELP, i don't know what to do with my camera. The little green light flickers when I open the lens to turn the camera on and then i hear a strange noise but the screen is blank
  • 1 more comment
  • borrell807 Nov 22, 2008
    it happens exactly the same in my camera
  • steppek Jan 29, 2009
    I am having the same issue. Any idea?
  • Bob Apr 10, 2009
    Exactly the same and I just had it repaired a few weeks ago !
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
mcomijohns
  • 477 Answers
SOURCE: Casio Exilim EX-Z70 lens error
yes I can help you lens zoom motor is out or the gears are stripped. goto www.digitalcamrepair.com for more help.
Posted on Jun 12, 2008
mcomijohns
  • 477 Answers
SOURCE: Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: Lens error causing camera to not work, HELP!!!
I just had the exact same problem on a friend's Exilim EX-Z75. Since it was useless as is, I was asked to investigate. It turned out to be a mechanical problem in the lense. I'm not too sure if it was a misalignment of the servo motor or if a gear popped out of a guide hole. In any case, if your lense goes in and out as it normally does, the problem is not in the main motor, but in a smaller internal secondary motor that adjusts the focus. Only try this if you are comfortable working with small tools and have plenty of patience. Took me about 3 hours start to finish. Warning: there is a capacitor that can hold a good enough charge to give you a jolt, possibly causing you to drop or damage the camera beyond repair, or short out your pacemaker. Keep your hands clean and avoid touching the circuit board and lense and display surfaces. Just in case you do get the camera working. Cycle the power button until the lense retracts completely. Remove the battery. Remove the case screws (6 on the bottom and 8 on the sides) and carefully remove from internal camera. The lense assembly is held in by some soft spongy spacers and a clip on the bottom corner of the lens compartment. Push the clip and the lense assembly should flip up revealing the back of the lense. Be careful to not put too much tension on the flexible circuit board. The CCD (that captures the picture) in the middle is held on by two screws. Remove that first letting it sit in the lense compartment. Then there is a circular plate that will reveal the focusing motor and gears. Remove the 6 screws and carefully remove the plate. There is a small motor and 3 gears that will be exposed. The center one might pop out. If it does, the small gear on the dual gear assembly faces down. You should be able to pick up the center focus unit high enough to make sure that the focus gears and rods are properly lined up in their guide holes and check to make sure none of them are stripped or out of alignment. The focus rods should be paralell to one another on the side of the focus unit. This is what I believe is causing the lense error problem. I would suggest after checking the alignment that you manually turn the gears so that the lens is all the way up. Turn the brass gear on the motor to make sure that all the gears are turning and moving the focus lense. If you think you have everything aligned properly, it's time to re-assemble the camera. Once you have the back plate and CCD put together, you could try to put the battery back and power up. If everything is ok, you should see a picture on the display and be able to take a picture. (Watch out for that capacitor.) If not, you might want to take it apart and recheck the alignment of the focus gears again. I had to do it twiceeven though it looked ok the first time. Remember, anything not lined up properly in there will cause the camera to malfunction. You should also have a greater appreciation for how sensitive a camera can be. DON'T DROP IT! Good Luck. Phil
Posted on Jun 10, 2009
pauman
  • 248 Answers
SOURCE: casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Posted on Jul 05, 2009
I get Lens error 2 msg as soon as I open the lens cover, then it vanishes, how to fix this problem in Casio Exilim-V8
HI
I BUY A DIGITAL CAMERA EX-V8 CASIO
BUT WHEN I WOULD TAKE A PICTURE , IT WAS DAMAGED AND ((LENS ERROR 2)) WAS APPEARED BUT I CAN TAKE PICS AND MOVIE
WOULD U PLEASE GUIDE ME???
PLEASE SEND YOUR SOLUTION TO ALIREZA.S@SNSIRAN.COM
THX
Feb 28, 2009 | Casio EX-V8 Digital Camera
Casio Exilim EX-Z60 won't turn on
I have this exact same problem with my camera. My problem wasn't with the lens or the battery, but the camera's connection to the battery. When I pushed the batter all the way in, I was able to turn the camera on. Right now, I have a tiny folded up peice of paper inside, pushing the battery up more inside. This is my quick fix since I am going to a concert!! If you are in a pinch, try this.
Jul 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Jun 12, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio EX-Z55 wont turn on after lens error
A lens error is something that can only be fixed my sending in to the repairs department. There is nothing that can be done at home to fix that.
Nov 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Lamp light
Does ur camera ever say "lens error"? It sounds like what I typically hear as a lens error and the only way to fix that is to send it into repairs.
Nov 21, 2007 | Casio Exilim EX-S600 Digital Camera
Lens issue with my Casio EX-Z50
I don't believe a "lens error" can be fixed at home. That is something that is going to have to be sent in. Sometimes if repairing the camera costs more than what it's worth Casio will offer you a trade up to a different model. Call the repairs dept and ask them about that program. Their number is 800-706-2534 and keep choosing option 1.
Jan 29, 2007 | Casio Exilim EX-Z50 Digital Camera
Dead
try taking your memory card out and then replacing the battery to see if you can get it to power on and get your lens to go back in. If that doesn't work you will probably have to send it in for repair.
Sep 11, 2006 | Casio Exilim EX-Z50 RED STAR Digital...
Hey Dockwise, i actually went to radioshack and they sent it in for me to their repair center and after what was supposed to be 4weeks but turned into 8 they sent it to Casios repairshop and Casio estimated the cost of the fix at 420$ and they said its uneconomical to fix it. I think i am just going to go to WalMart and try to return it as if i bought it there beacuse i see no other solution then just throwing away a perfectly good camera beacuse of a glitch
Aug 26, 2006 | Casio Exilim EX-Z750 Digital Camera
Casio EX-V8 Digital Camera Logo
103 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
