Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Griding sound in Ice Magic Plus box in freezer compartment.
There is a constant griding sound in the Ice Magic Plus compartment in the freezer compartment. The ice maker is making ice.
  • 750 Answers
Hello garydeanr,
Welcome to fixya.
You said,, There is a constant grinding sound in the Ice Magic Plus compartment in the freezer compartment. The ice maker is making ice.
What is your exact model number and How Old is your fridge?
I'll be able to run it through the repair system and check for you!
Waiting your response!
I believe that,
From here this sounds like one of many normal sounds. is a normal sound.
You can go to this site and scroll to page 9 where it will tell you all the normal sounds your fridge can make.
I tried to cut and past it here for you, but it is not copyable from the site!
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202220699.pdf
I think you can rest assure that it's okay.
Huuum ,
Please remember to leave a rating!
Posted on Oct 21, 2008
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
Ice Maker WR30X0327 Freezing Over I have an
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
Mar 03, 2017 | Refrigerators
I have a whirlpool side by side with water/ ice magic plus my freezer is producing ice on the walls and top of freezer. my ice maker is making a noisewhen i close the freezer door (my seal on the ice...
yes it sounds like the unit is not defrosting. u might need to check defrost timer and then u might even have to change out your defrost heaters and termnation switch. try that ok. lkater gator.
Feb 15, 2011 | Refrigerators
Ice maker stopped working
The water line may be clogged with debris. there is sometimes a filter in the water line to the fridge, or also a screen filter may be located at the point where the water line connects to the fridge. If they are clogged, your ice maker will not make ice and may even burn out.
Check that the water in the line is flowing freely. Also it might be a good idea to defrost the freezer in case you have a ice buildup in the freezer compartment. To do that, empty the freezer and blow air into the freezer for 30 minutes while the power if off. Note, keep the other side closed to protect the milk and other perishables.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is not making ice. water line is fine. with door open and flapper held shut, the sensor light is constant.
I just finished with this problem and found it to be a bad ice maker itself. The back sensor part shorted out. Replacing it is easy and price is 185.00.pricey but very simple.
Nov 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
280 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
