Question about Car Audio & Video
Ford ka stereo
I recently left the lights on overnight in my Ford Ka and the battery ran down requiring me to get a jump start. The other fall out from this was that the stereo (the standard Ford Ka stereo) seems to have gone into some kind of lock-down mode requiring me to input a code (4 numbers) to get it working again. As far as i know, there has never been a pass code selected for this so i have come up against a brick wall. Is there anyway i can get the stereo working again with out the code?
  • rawsongeoff May 11, 2010
    all you have to do is press 2-6 and it should give you a number M1234 THAT STARTS WITH M or take out the radio and get the M number of that email me with the m1234 number and i will give you the code
    rawsongeoff@aol.com
  • 25 Answers
Check in ur manual for the car to see if the radio is there if not go to ford with ur reg no and chassis no and they should be able to give u the radio code
Posted on Feb 18, 2009
My ford ka will not crank only clicks battery fully charged it will start with jump from other started car but when try to start it only clicks and brr sound dails jump on the dash
I had a similar problem with a Volvo ages ago. With a new battery, I paid to have an alternator replaced over and over. Finally paid to have the alternator changed over to a generator. Turned out - the new battery was the problem. It was ... broken from day one. Just a thought.
Dec 18, 2017 | Ford Cars & Trucks
Hi I'm just wondering I have a ford ka 2000 and need to find were the fog light is located any help much appreciated thanks
Switch is usually located on the dash for fords on the left side of the driver. If not there then look for a rotary type switch on the signal arm or washer/wiper arm.
Jan 18, 2015 | 2000 Ford Ka
What is wrong when the milage indicator starts to flash on my KA car
It needs a proxy alignment in your local dealership, it can be caused by flay battery, leads being disconnected, a bad connection, being jump started or a faulty alternator, what happens is the ECU fails to locate certain systems due to one of the above mentioned and flashes the mileage to warn of the issue. Its a common fault in Ford KA's and easily rectified in your local dealership. Hope it helps.
Aug 04, 2014 | 2000 Ford Ka
Why driving my KA it just stopped and will not start
does the engine crank over.
if it does, do you have both keys to the car,1 red 1 black
the red one is the main key and is the master key if this dosent start the car then i would surgest the car imobeliser/alarm system fuse
Mar 21, 2013 | 2000 Ford Ka
Code for ford ka serial number m023337
Recently purchased this decode software for my business and it seems to be working fine. I ran your serial number and it gave me a code of 5380. If you wouldn't mind by letting me know if it worked or not. Want/checking to see if I got my money's worth. I would be grateful. You can reply/comment here or email me directly at csautomotivecars@att.net. Thanks and I hope it worked for you !
Jan 29, 2013 | Ford Car Audio & Video
My Honda Accord wont start even with a jump. The lights come on but wont turn over. No click, no sound, no nothing
IT's those short drives that burn down a battery! The starting of an engine requires mucho electric to get it running. The alternator then charges the battery, but slowly! If you also have the lights and stereo on it is even slower. Get the battery FULLY charged with a commercial battery charger. Then check to see if the alternator is charging up the battery after you start it. If not, replace the alternator. If the battery dies overnight or in a few days...replace the battery.
Jan 24, 2013 | 2005 Honda Accord
Hi, i need to put water in my Ford Ka because the light is flashing and havent done it for a while. There are three tanks under the bonnet, one says power steering fluid so i assume its not that one. Then...
Hi, I'm not familiar with the Ka,but did the light go out after adding water? There are only 2 car fluids that are red. One is auto transmission fluid and one is a type of coolant. The transmission reservoir is in the pan, so I doubt you could have seen red fluid in the transmission without pulling up the dipstick. You can also try disconnecting the level sensor on the reservoir that you added water to. If the coolant light goes on and off when you short the terminals in that connector together (use a paper clip), then that is the coolant reservoir. My guess is you got it right.
Jan 01, 2011 | Ford Fiesta Cars & Trucks
Hazard warning lights and horn on a 2006 Ford KA don't work
Hazard warning lights and horn on a 2006 Ford KA don't work but indicators do
Aug 20, 2009 | 2003 Ford Escort
Car Audio & Video Logo
423 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
