Question about Dell Dimension 3100 PC Desktop
Sleep mode dell dimension 3100 will not reboot after sleep mode.. 1st error was" 1720" ask to reformat the hard drive. i did that but the pc still doesn't reboot. the screen message say "move the mouse or click the power button to restart" but that message only appers briefly when the monitor is turned on and off quickly. i have tried restarting the pc and pressing the f8 button several times but nothing happens... just keep getting the the sellp mode beeps and thats it...... do u have a solution for me
  • 68 Answers
Try to shutdown the system and remove the power cord, after you remove it press the power button for 5-10 seconds and then check support.dell.com site for bios updates, and double check your power options.
Posted on Oct 31, 2008
    Scholar:
  • 87 Answers
If you reformatted the hard drive, you have erased everything. If you have restore or backup disks use them now.
Posted on Oct 21, 2008
How do i get my dell dimension 3100 to play dvd's and dvd-r's sonic cineplayer doesn't want to do anything for me
Try the Open Source VLC player software (from videolan)
If still no luck, chances are it's your DVD drive (you do know you only get 3 changes of 'Region Code' before it locks up ?)
Nov 11, 2012 | Dell Dimension 3100 PC Desktop
Dell 3100 will not power up
Hardware issues: (most likely the motherboard)
Start by removing:
Ram Chip one by one. See if it will change anything (if it doesn't put that back in)
Cd Drive
Hard drive
Anything else (video card, PCI components)
Dec 12, 2011 | Dell Dimension 3100 PC Desktop
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
My dell dimension has gone to sleep mode by it self, and now it does not go on?? tried to take out the power cord and start but straight away it goes to sleep mode??
bhupesh626
When the system is going back into sleep mode what color is the power button flashing. It should like the system my not be going into sleep mode but have a more serious problem.
Also let me know what you see on the screen as you turn on the system.
Another thing to try is after you unplug the system hold down the power button for 30 to 45 seconds. This will reset the power state of the system. Note if you have the system plugged into a power strip you will want to reset the power strip too.
Issken
http://www.fixya.com/users/issken
Feb 03, 2011 | Dell Dimension 3100 PC Desktop
My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
Feb 21, 2010 | Dell Inspiron 1501 Notebook
WINDOWS WILL NOT BOOT. Possible virus turned off my protection. cannot get windows to reboot. did a restore . keeps trying to update with no results.
hey man its a trojan .. try to enter into the safe mode. if it fails then no other go either reinstall or reformat and install(i recommend this one).
Oct 30, 2009 | Dell Dimension 3100 PC Desktop
Dell DimE310 wont reeboot
You should be able to get a start up software that is a portable software that can reside on a usb stick. Hunt for this software using google. Call out for a portable xp or what ever OS system ... and you can use this as a startup. When it does start up go to safe mode and resolve the hard drive errors with trojan virues or defrag, then use error professional pro to clear out dll and other problems. Most times all the problems are found it the unused program paths and other internet cookies and affliates thet go along with the rest of the errors. You can also get Regcure, this is also a good system problem solver. This softwae really works.
Jun 17, 2009 | Dell Dimension 3100 PC Desktop
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Hi I have a 2 year old dell Desktop Dimension 3100 and I cant sort out a RunDLL error /32 all the registry fixes I've tried R useless,many thanks
Rundll32 is a process that is needed by your operating system to run properly, If this is corrupted, then some of your major processes fails as well. What I can recommend is for you to repair your operating system using your windows cd. (not reformat)
when you reach the drive selection (where you can see what drive the windows installed) you can press "R" for repair. It will automatically repairs you Windows without modifying your settings, installed programs, just as it was.
If you have problems doing this, you tell me.
Mar 02, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
145 people viewed this question
Alun Cox
