Question about JVC Televison & Video
JVC HM-HDS4 Hard Drive failure, how to obtain a replacement
  • onchman Aug 01, 2010
    Hello FixYa,
    I have made a mistake in using you assistance request page, and repeated an old request. The assistance I wanted to request is as follows:-
    Have Canon MPC200 Printer. Following "Waste tank nearly full" warning, have used procedure to reset EPROM, but at the end of the procedure, it appeared to lock in some way, resulting in having to Unplug Printer. Now Printer will switch on OK, and can access the Service system & do test prints, but, although the computer detects the printer & lists it in My Computer, the computer says it is unable to communicate with the printer, Restarting the "MP Service"(which it recommends)does not cure the problem. Have un-Installed & Re-Installed printer driver, but still won't communicate. Can anyone offer a method to re-establish communication with the printer please?
    Is there any way of correcting this error please?
  • 8,197 Answers
  • 10,594 Answers
This article has hard disk replacement details about JVC HM-HDS4 vcr.
Click above link and follow the instructions.
Hope this will help you.
Thanks.
Posted on Jul 30, 2010
JVC Everio GZ-HM 35 choppy playback
My jvc gz-hm35 does not turn on. I tested the charger it works but I dont know about the battery. It does not turn on with the charger. Does anybody know a solution? Please
Nov 23, 2012 | JVC Everio GZ-HM30 Camcorder
I try to change the HDD. The old one is out of order, and ...lost by the last owner. I'd like to replace the H.D.Disk by a new one, put on it the right firmware, and hope it'll work :D ! So, 1/...
go to a computer shop and buy a kingston solid state hard drive-250 gig for around $65.00 aud
next obtain a copy of win 7 with a registrable licence code and insert it in a cd drive
turn the computer on and hold down the delete key until the bios screen appears
move to boot tab
select cd as first boot device , yes and hit the esc key
turn off the computer then restart it
the bios direct will activate the cd and load the program into the hard drive and you are up and running
when finished , go back to switch off and do the bios start again and this time set the first boot back to hard drive
A 250 gig sshd is equal to 500 gig disc type and will not fail as there are no moving parts
Aug 27, 2017 | JVC DRMH20 DVD Recorder
I am facing problem with my samsung hard disk it gives error of s.m.a.r.t command failed and hard disk is in warranty period
The SMART monitoring software analyzes information from the drive to determine if some component is not functioning within spec. The system is not 100% accurate and often failures are detected when there is no failure. However, if your drive is in warranty and you wish to avoid data loss from a failure you will want to backup your data ASAP.
If the drive is within its warranty period you should start making arrangements to RMA the drive and receive a replacement.
After you have backed up data that you can not recover elsewhere contact the drive manufacturer or the store where you bought it, if it is within the return period, to obtain an RMA number and the required information for return
If the SMART error is preventing you from booting the computer or using the drive you can disable SMART monitoring within the bios. This will eliminate the monitoring which will eliminate the error message.
Jul 15, 2010 | Computers & Internet
Everio software
my JVC Everio GZ-MG330 keeps saying "recording failure" when i press record. how do i fix this?
May 08, 2010 | JVC GZ-MG330 HDD Camcorder
When turn on power button shows up red and can't play any games
This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
1. Turn off the console.2.
Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive3.
Reattach the hard drive, and then turn on the console.4.
Obtain the latest automatic update for the Xbox 3602.gif. To do this, connect to Xbox Live.5.
If you continue to experience this behavior, contact Xbox Customer Service.
Nov 23, 2009 | Microsoft Xbox 360 Console
Capture HM-DH5U Video into CS4 Premiere Pro
Personaly I would use either windows movie maker, nero, or the applicatiom that came with the camera just to get it to the PC.
From there It would be easier to edit etc.
Aug 14, 2009 | JVC HM-DH5U 35-Hours Video Recorder
Acer Aspire Hard Drive failure
any laptop Hdd will work as long as you know whether it is SATA or IDE.
The casing around the Hard drive will be different, but can easily be put onto the new drive, but be careful of static and dont drop it
Feb 02, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
HARD DISC
If you bought it new then back up any files and take it back to the shop. If it's a second hand unit then you need to immediately back up to disc or pen anything you want to save. You are being warned that there is an issue with your hard drive. If this fails then you will lose all your information and computer won't fire up until you fit a new hard drive and install an operating system (if you actually have one). Once you have safeguarded your files it might be worth checking if your laptop is running too hot, which can damage a hard drive, is the fan switching on. There are programs free to download that can test the temperature.
Aug 27, 2008 | HP Pavilion DV6500T Notebook
Televison & Video Logo
131 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
