Question about Frigidaire GLEQ2152ES Electric Dryer
Beeping dryer Like the other questions i have read, my dryer turns on on it's own and beeps constantly, 3 times, ove and over to the point i unplugged it for 2 days. It was ok for the next week or so, then it started beeping again. it's still drying, i took the filter 'screen' out and vacuumed the inside, the sensor was packed with lint, but it still didn't solve the beeping. any advice?
    Problem Solver:
  • 3 Answers
Is your lint trap in the front? If so, there should be two screws on either side of it. Undo those screws to see if it is clogged. I had the same problem with mine. I had to clean it out by hand and then use a vacuum to get down further for the rest. I also had to disconnect the exhaust hose from the back, that can also build up lint in it, clean that out the best you can, check where the hose connects to the wall and to the dryer then clean any lint out that has built up. You should be able to disconnect the hole on the bottom of the dryer. It should be connected by one little screw. You can pull that out once you have removed the screw so that you can reach inside to check for more lint that can be removed. There should also be a small vent on the bottom left hand side, remove that vent and that gives you access to the bottom of the dryer, if you lucky unlike me there won't be too much lint stuck in there. I used one of the air spray cans that you use on a computer to clean all the lint off the motor, that could cause a fire. Once you have cleaned all the lint that you can hook everything back the way that is was and it should be fine. Since it is your lint light that is coming on then that should be your solution. You have a clog somewhere in the areas I told you that needs cleaned. Good luck.
Posted on Oct 23, 2008
Krups coffee maker constantly beeping, even when no water or not turned on, when making coffee it beeps turns off then beeps and turns on - getting to the point of just unplugging to stop beeping.
Hello Linda Foster,
If there is NOT an OWNERS MANUAL immediately
available.. there are a huge selection of KRUPPS
machines...
Chose from the attached list...
Find the trouble section... Read & heed
Results for krupps coffee maker var myCallback function document ready...
Hope this helps...
(or REPOST with model number for BETTER QUALITY answers).
Carnac the Magnificent
Oct 25, 2017 | Krups Coffee Makers & Espresso Machines
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Frigidaire dryer model LEQ1442ES0 beeps then shuts off after about 10 seconds. Four lights blink 3 times. Error code for?
Hi Robert, thank you for allowing me to assist you!
Constant beeping is often an indication of a possible malfunction. Let's try reprogramming the dryer by either flipping the household circuit breaker off or unplugging it. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error from the main control board, a potential wiring failure, faulty door lock assembly or the timer itself may not be operating correctly. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
Sep 01, 2013 | Electrolux EW1209i Front Load Washer /...
Whirlpool cabrio dryer
this is a signal from some codes, read your owner manual and see what is the indication with the beeps.Normally after your clean the filter and exhaust vent, and continuos beeping the control board is faulty, replace it.
God bless you
Jul 13, 2013 | Dryers
How do you turn off the beaping on a Haier Clothes Dryer?
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
Jul 09, 2012 | Haier Dryers
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Evenheat MOD# 110 62056100
okay, kenmore elite have had these problems so often, you need to replaced the touchpad, not the board, jjust the touchpad, it cost around $150.00.
Sep 10, 2009 | Kenmore Dryers
Kenmore oasis dryer cycle signal beeping constantly
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the unit first.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
Keep getting 3 beeps and the lights come on while its beeping.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
Mar 24, 2008 | Frigidaire FEQ1442ES Electric Dryer
Constant beeping and will not re-boot
Question- the beeping, is it short (1 second beeps) or long (2 or more seconds) and how many before it stops? or doesn't it? does it have any rhythm? The beeps correlate to some hardware problem, if you want to check the beeps yourself, just google "Bios beeps" and it will bring up a table of what the beeps mean.
J
Jan 07, 2008 | Computers & Internet
Frigidaire GLEQ2152ES Electric Dryer Logo
483 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
