Question about ViewSonic Televison & Video
ViewSonic N2060w model No:VS11287-1E need a code for Sky remote control please
5 Suggested Answers
Emsy32
  • 3 Answers
SOURCE: Sky remote handset will not operate mute. volume etc.
Go to interactive
Select Number 5
Then select the remote option (5) You will then get a list of tv models with codes, follow the directions on screeen
Posted on Jan 06, 2008
SOURCE: Sky remote setup codes
your code is 1239
Posted on Aug 18, 2008
SOURCE: I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
Posted on Jun 03, 2009
  • 21 Answers
SOURCE: Sky code
Sky remote codes: 0805 1783 1785.
Here are some other codes that may work with the Viewsonic: 1295 1694 1697 1800
Posted on Sep 14, 2009
SOURCE: am unable to operate on/off button on remote
Dropped it onto a hard floor an d bingo! O.D.
Posted on Nov 22, 2009
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Televison & Video
Need a sky remote code 4 new tv toshiba zv555d
please follow the steps below:
TV
RED + SELECT
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jun 04, 2009 | Toshiba 42H81 42" Rear Projection...
May 16, 2009 | LG Televison & Video
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Televison & Video
Sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Apr 26, 2009 | Televison & Video
SKY REMOTE CONTROL CODE FOR SHARP LC-37X20E TELIVISION
You need code 1221 for this tv. I have the same tv, and using a rev.6 Sky+ remote, everything seems to work fine with that code.
As Sky seem completely unaware of this television, and possibly countless others, people should use the following site for a more complete remote control list than Sky themselves have:
http://sky.uebv.com/
Jul 18, 2008 | Sharp Televison & Video
Remote control code
try these codes
0063, 0163, 0266, 0355, 0455, 0555
good luck!
Feb 08, 2008 | Televison & Video
Televison & Video Logo
232 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
