Question about Hitachi 57S715 57" Rear Projection HDTV
Tv power will not come on tried un pluging and pluging in diffrent outlet still will not work
  • noah johnson Jul 21, 2006
    would love any help
  • noah johnson Jul 24, 2006
    My tv will not power on. I do not see any red led lights on. The only light that I see on my tv is the blue power light and it is not coming on. I was watching tv on the 20th of July and decided to turn the tv off from my direct tv remote. When I went to cut it back on with both remotes, the tv would not respond. No lights or sound at all. I also checked the plug and chord.
This looks like the solution to my problem. I just want to know how much these parts that we are talking about? And where is the best place to buy parts?
Posted on Jul 26, 2007
  • 1,476 Answers
You did not say if any lights are lighting up on the unit. If the red LED is lighted or blinking your power supply, and fuses, are probably OK. If the LED is blinking it means that you probably have a problem in the high voltage circuit. Usually the Horizontal Output Transistor is shorted. Could be caused by a power surge, lightning strike or shorted flyback. If you know TV safety, how to use a DMM, soldering techniques and are good with tools you might be able to fix this. Unplug and open the unit by removing the back. The HOT is near the flyback (a large round cylinder with a large red wire coming out of it) usually on the right side, mounted to a large piece of aluminum (used as a heat sink). Using a DMM check the HOT. If shorted this is your problem. Replace the HOT and the flyback. Check all resistors and diodes in the circuit for problems and replace any out of specification. This may solve your problem. If not the HV Block could be shorted also. This is part of the same circuit and is where the wire from the flyback goes. If after replacing all these parts the unit still is not working you will proabably need a repair tech to look at it. If you do not feel confident doing any of the repairs listed above seek the help of a reputable repair shop. This repair should not be very expensive in relation to the cost of the set. Good luck.
Posted on Jul 24, 2006
  • Kim Yearick
    Kim Yearick Jul 24, 2006
    If you know that the unit is getting power and there is no response at all (nothing lights up) you could have something as simple as a blown fuse, a problem with the power supply or as I said before a shorted HOT transistor. Checking the fuses are straight forward. Remove the back, with the unit unplugged, using a DMM check the continuity of all fuses. There could be one or more in the power supply and one or more in the HV section. If you do not have troubleshooting skills you will need the help of a qualified repair tech as these problems can be very complicated (or very simple) but knowing where to specifically check is tough unless you are trained and familiar with troubleshooting. It's hard to give you a cost estimate with no idea of what could be wrong but I would think that no matter what it is it would be cheaper to repair the unit than replace it. Good luck.
Tv not getting no power at all
Check the fuse on theit my be blown if it is check the diodes around it they may be shorted also check the cap also where the power come into the board
Jan 28, 2010 | Mitsubishi WD-52525 52" Rear Projection...
2 1/2yr. old Protron Tv will not turn on. power light dose not light... the outlet it was pluged into is live & running a diffrent Tv now. Can you tell me if the protron Tv is shot or is there a fix?
Make sure there is no other power switch anywhere. The problem may be bad caps on the power supply board, or the board itself is bad. Parts for some of these Protrons are hard to get. If its the caps it should be a cheap fix, depending on the repair shop, but the board could cost $100 or so, not including shop labor to install it.
Sep 01, 2009 | Televison & Video
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
PS3 doesnt work
ok so try pluging up to a diffrent tv if it comes on then teres pobley somrthing wrong with ur tv u bought or u froze the ps3 so change it
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Sony color rear video projector tv, videoscope, 1994
first things check the outlet for power.
chech and make shure your surge protector is in the on posishion.
try pluging sumthig else in wer the tv will be pluging into.
at least you know if its the outlet or the tv set.
ok now press the power button on the tv set not the remote.
dose it work.
ok problem solved.
if it did not work you can have a tech see if the internal fusse is good or bad.
i will need the model number to look futher into tech repair.
I will do this for you if you need it done.
thanks.
daniel
Jan 13, 2009 | Sony KP-51WS510 51" Rear Projection...
Kenmore 21875
My first recomendation would be to try pluging into a diffrent wall outlet as well as something that is on a diffrent circut . It is a known problem that the pins inside that make the connection could be worn out . There are several pins from the one on the hose to the handle ect , check all componants to see that where the connection is lost you will find that you will need to replace that componant
Sep 17, 2008 | Kenmore 21513 Vacuum
Hitachi 57S715 57" Rear Projection HDTV Logo
228 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
