Question about Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam standmixer model MM 1000 I would like to replace the two beaters
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Model 2486 Sunbeam hand mixer
http://buyitnow64.stores.yahoo.net/sunbeammixers.html
Hope this helps
Posted on Feb 08, 2009
SOURCE: beaters
changed my mind
Posted on Jun 24, 2009
whlyon42373
  • 71 Answers
SOURCE: Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Posted on Dec 15, 2009
Testimonial: "I will try the rubber bands the next time I use the mixer - Thank you"
  • 3 Answers
SOURCE: Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Posted on Jan 25, 2010
Where can I buy replaement beaters for a Sunbeam Mixer Model MM1000
Look for a nearby dealer or repair shop. If that doesn't work, try http://www.goodmans.net/d/159/sunbeam-mixers-parts.htm
Dec 16, 2014 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
Mixmaster junior
This is an issue you will have to take up directly with Sunbeam. Be sure to provide specific model information
Aug 04, 2013 | Food Mixers
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
My mothermixmaster's beaters need replacement it was a wedding gift in 1955 - where do I find spare parts?
Hello. Thanks for choosing Fixya! Actually, Sunbeam hasn't changed their beaters since 1936 for most models. I believe your best bet is to order from a Sunbeam Factory Service Center. Here is the link that will get you there. http://www.householdappliance.com/sunbeam_oster_beaters.html
Good luck with it. Regards, J.
Nov 16, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Dec 02, 2007 | Sunbeam 2350 Heritage Series Mixer
Sunbeam 2370 MixMaster Series Stand Mixer Logo
337 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
