Question about Sony STR-DE475 Receiver
Center speaker channel
The center speaker channel turns off after a short time as though the current limiter has kicked in. I have tried the speaker by using a different one but no change.
All other functions seem to work ok
Thankyou
Bryan Keane
U.K.
  • zero_hifi Nov 17, 2008
    I got the same behavior on my DE-475... with few issues more.
    it brings the same behavior for SR and SR outputs as well...
    Problem Solver:
  • 13 Answers
Audio amplifier is the main problem,check some resistors in audio out.
Posted on Oct 21, 2008
HI, I have Receiver Marrantz SR- 5005, the center chanel does not work, please tell me what happened and solution to fix the problem. Thanks
Get the manual and open it up to the part where speakers are defined, then test it/them with tones. Try swapping a different speaker into the center if the current center channel speaker still doesn't work.
Web search "Marantz SR-5005 manual" (note the spelling)
Aug 07, 2011 | Audio Players & Recorders
My system is set up with an A & B (inside and outside) front side along with back speakers and a center speaker (for dialog on TV & movies) the center chanel does not turn off when you switch from...
Only the front speakers are affected by the A/B switch.Press the 2CH/A. DIRECT button on the remote to force the receiver to only output sound to the front speakers and mute the other speakers that are not being used.
Apr 02, 2011 | Sony STR-DG820 Receiver
PROTECT is flashing on our Sony Digital Audio/Video Control Center
PROTECT means the receiver is automatically powering down to protect it's amplifiers. Top reasons are overheating, which can be caused by poor ventilation, covering vent holes, excessive volumes for long periods of time, or it's actually just that hot in the room, which, with the current weather, I've encountered in clients homes before. The other option, and just as common if not more so, is that the speaker wire outputs are shorted out and are causing the amp to turn off. The easiest way to test this is unplug all of the speakers and turn it back on. If it still says protect, then it's either too hot or there is a physical problem with the protection circuit and needs to be serviced (this would be a good time to kick yourself for buying a sony receiver). If it DOES power on, plug in the speakers one by one, and if the amp goes into protect mode as soon as you plug in a speaker, it's an issue with that one. Check for short circuits in the line (kinks, frayed ends, staples going clear through the wire, etc). If the wire looks good, try putting a different speaker at the end. If a different speaker works, then the speaker is blown, which gives 0 continuity, and the receiver is correctly protecting itself from the high impedance load. Change the speaker.
Sep 08, 2010 | Audio Players & Recorders
The DDT light on one channel stays on,but I can't find a reason why? What can I do?
Disconnect the speaker wiring and speaker on the bad channel. Turn the level control(s) all the way counterclockwise and turn the amp on. If your DDT (limiting) light remains lit, it's time for a visit to your nearest certified Peavey service center....G.
Feb 05, 2010 | Peavey Pv 2600 Power Amplifier
Center channel is not working . Surround sound from center channel not working. I have found two fuses blown and replaced . when unit turned back on o try they blew again
First make sure the centre speaker is not shorted, try a different speaker and new fuses. If this fails and you have electronics knowledge here is the link to the service manual...
http://www.enusbaum.com/blog/tag/service-manual/
The driver or power output device (FET or Transistor) is probably shorted if the speaker is not shorted.
Jun 10, 2009 | Harman Kardon AVR 135 Receiver
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Center speaker
When you turn on zone 2 you are in stereo mode. The center speaker and the rear speakers will not function in stereo mode.
Try turning on zone 2 and then switch the surround mode after that and see if it helps. If it turns the zone 2 speakers off when you do that, then your unit does not support what you want it to do. Center speakers only work in listening modes other than stereo.
Most A/V receivers are designed for watching movies and they did not take this use into consideration because zone 2 would normally be in another room such as the way you have yours set up. If somebody is watching a movie in one room they would not need to hear it in another room. You would think that the designers, who are very talented to be able to come up with these type of units, would have just a little more imagination on how people would be using the equipment. Go figure!
If your receiver has a 5 or 7 channel stereo mode, it may work then. You can try, but I don't think it will help.
I have even seen some receivers that have the center channel amp being used for the zone 2 output as well. It just switches what speaker output jacks it goes to with a couple of relays which makes it impossible to use the center and zone 2 at the same time.
I guess they are just being cheap by not putting another output channel in the unit and sharing the one they have.
Why would anybody want to use the center and the zone 2 at the same time???? Sad, isn't it.
Hard to believe that such a nice receiver would have such a rediculous limit designed right into it. But they really do design them like that.
Let me know if you need more help.
Dave
Aug 08, 2008 | Yamaha RX-V2300 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
RX-668V - Center Speaker Channel
have a tech check your set it is a bad cap that that bias a very small voltage to that circuit or it could be cold solder.good luck.
Apr 15, 2007 | JVC RX-668V Receiver
Sony STR-DE475 Receiver Logo
108 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
