Question about LG LSC26905TT Side by Side Refrigerator
OUTSIDE DISPENSING AREA POPPED LOOSE FROM DOOR
I have an LG side by side refrigerator model number LSC27926ST. The dispensing area on the freezer door popped loose from the door when the plastic was removed. How can I resecure the dispensing area back to the door? Any help would be greatly appreciated.
Randy Karg
e-mail address
rckarg@cableone.net
  • 1,543 Answers
Most likely some of the plastic tabs broke when the part was removed. You will most likely have to replace the recess (or their term, Decor Assembly) part number ACW34923401
Posted on Oct 21, 2008
How do you clean the ice and water dispenser on the freezer door of a whirlpool model num ed0gtqxkq00
Remove the drip tray then pull the bottom of the dispenser cover down and out, it should pop right off.
Mar 14, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have lsc27926st. The water tube to the ice tray froze and I used a hair dryer to unfreeze it. After the tube was clear the water will not refill the tray. I have turned the on/off switch a couple of...
from the ice freezing tube may have caused valve to burn up on unit... these are normally plastic water valves on back side of unit lower right side... very common problem... i am a lg oem authorized servicer parts usually come from lg electronics in alabama unless you have a local supplier that you can go to...        the ice makers themselves have been problems on these models as well... 1 year warranty is all they give and usually 1 year 2 days they go out...   let me know if i can help anymore    ACHEATINGUNLIMITED@YAHOO.COM         TEXAS BASED APPLIANCE /HEATING AND AIR COMPANY
Dec 31, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Flap ice dispenser on door dislocated, screw loose
model? GS6NBEXR
Have a drawing that shows the dispenser is worked on from front. I will be here if you need, Also need the complete model number, Thanks, Sea Breeze
Mar 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loose freezer door handle on my whirlpool side-by-side refrigerat
you should be able to pull straight up on the handle (with force) and it will come loose from the retaining screw. usually its just the retaining clip that comes loose from the door but sometimes you will have to replace the entire handle to repair the unit. if your not having any luck getting it off message me with a complete model number for your refrigerator and i will see if i can get you a little  more detailed information. thx peyton
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenmore - Side by Side condensation in water/ice dispensor area
maker sure your flapper is closing all the way the trim plate will come off its snapped on once you get it strated it will come they are a bear use butter knife to pop it loose on cornor first hope this helps
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
LG LSC26905TT Side by Side Refrigerator Logo
129 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
