Question about HP LaserJet 4000 Printer
SEQUENTIAL LOADING OF PAPER
DEAR TEAM ,
IM HAVING AN HP LASERJET 4000TN WHICH IM USING FOR ALMOST FOUR MONTHS NOW.
BUT THIS MORNING WHEN I SWITCH THIS PRINTER , IT STARTED LOADING BLANK PAPERS CONTINUALLY UNTIL ALL THE PAPER TRAY GOT EMPTY.
DUE TO THE CONFIGURATION PANEL WICH IS ALSO IN NETHERLANDS LANGUAGE I COULD'T DO ANY BETTER THING.
PLEASE IF ANYBODY KNOW WHERE I CAN GET THE ENGLISH VERSION OF THE LASERJET 4000 TN TROBLESHOOTING MANUAL HE SHOULD SEND ME THE LINK TO MY E-MAIL : doe_freeman@yahoo.com
THANK YOU
HAVE A GOOD DAY.
FREEMAN.
  • 37 Answers
I sent you the userguide downloaded from HP website.
Thanks.
Posted on Oct 21, 2008
(hp 4000 printer) A piece of paper is stuck between tray 2 and under just before the toner cartridge. I can lift the flap on top of the paper after removing the toner cartridge, but cannot dislodge the...
Probably the way to go is to remove the toner and tray 2.
lay down a bunch of newspapers on the floor (not a rug). The printer is unplugged at this point.
Turn the printer over and lay it down. Take a sheet of paper and fold it lengthwise in quarters.
Manually feed the folded paper into the paper path from the bottom. Push and pull the paper thru
the paper path. The object is to push the small piece out where you can reach it.
It's not the easiest thing to explain. You always want to go in the direction that the paper moves thru the printer. This is why you start feeding from the bottom.
You know that there is a piece of plastic that is above the feed roller for tray 1 that you can pull out to give you more room.
Feb 18, 2011 | HP LaserJet 4000tn Printer
Error 13.1 paper jam but there is no paper jam
Well... you've either got a bad sensor, or there is something stuck in there. It doesn't take much to signal the jam.
Assuming you've been using it for a while, and the same type of paper, you might try some canned air and blow out the paper travel areas. (stay away from the toner cartridge.. remove that when you start blowing air around). If you're lucky this will dislodge whatever is tripping the sensor or you may see a small piece of paper fly out.
Carefully check the entire paper path and even pull out the supply paper, ruffle through it back and forth then replace it and give it a try.
Hit clear and/or power it off for a minute then back on... hopefully you had it off when you did all the above.
If that doesn't clear it, again, may be a bad sensor, or something stuck you can't find. In either case you're going to need a technician to get further towards getting the machine back in working order.
8^)
Jan 04, 2011 | HP LaserJet 4000tn Printer
Can I print to my HP Laserjet 4000TN printer wirelessly?
Only by plugging it in to either a wireless hub, or access point.
I don't think there was a wireless IO card for this printer.
Feb 12, 2010 | HP LaserJet 4000 Printer
PRINTER WONT PRINT
If you has been connected your printer via USB be sure that the printer port is "USB Virtual Port" and NOT Lpt1
Oct 07, 2008 | HP LaserJet 4000tn Printer
HP Laserjet 4000 Error
It is asking for an envelope. Check your page setup and/or your tray configuration. Also make sure your paper stops in the tray is set at the type of paper it is for.
May 30, 2008 | HP LaserJet 4000tn Printer
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Poor Print Quality
I would start by changing the paper or even leave the paper in the son for a while. Paper usually gets damp, espesially durint the evening and then using it early in the moring. If this do not work you will have to change the cartridge.
Mar 05, 2008 | HP LaserJet 1020 Printer
HP LaserJet 4000 Printer Logo
Seeker5211
Seeker5211
