Please give me the name of a printer that WORKS with writing checks in Quicken using Windows Vista 64. My HP all in one does not - printer jams every time.
  • vrrose Oct 21, 2008
    The printer problem on my HP 3310 is a problem with compatablility between Intuit - Quicken and Vista 64. It has nothing to do with paper or thickness of paper etc. It ONLY jams in Quicken and didn't ever jam before I got my new computer with Vista 64. Program works fine on XP using same printer and all other programs work with this printer.
    I would like to find a printer that works with Quicken and Vista 64 guaranteed. Hopefully a cheap one because I love my HP 3310, but need to print my checks.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    well..the epsons work nicely..and so do the canons..
    Master:
  • 538 Answers
Hmmm....seems that perhaps this is a printer settings issue in Quicken. the Vista 64 bit is not an issue, UNLESS, that is too much horsepower for the CPU inside..so, try a canon or epson printer, which are clearly superior. products.
Posted on Oct 21, 2008
    Sergeant:
  • 306 Answers
HP will work. The jam is a paper problem not a hardware or software issue. Try line feeds without printing. HP also makes the best printer paper so don't skimp on that. Moisture in the paper is the most common paper jam problem aside from debris getting into the rollers. If line feed fails then physically inspect the whole paper path. I have Canon, Epson, Dell, HP and Lexmark printers with Quickbooks Pro. They all work. Paper is your problem barring a banana falling into the rollers. Never leave paper in a printer for a long time as it will stick to itself. Steve
I have Quicken 2009 and Windows Vista, HP Printer
I've tried off and on for a year to try to get assistance from Quicken and HP because my Quicken reports would not print. Everything else printed just fine. It was so frustrating because nothing worked. I needed to get reports to my accountant and thought I was just going to have to hand write the reports. In the end, I took a photo of the screen (with the report showing), downloaded the photo to the computer, tweeked it a bit with my photo software, then prrinted it. How goofy is this to get a report from a program that is supposed to make my life easier???!!!
Aug 19, 2009 | Computers & Internet
I have an HP deskjet D1560 printer. I'm using Vista 64 bit operating system. I can print from my e-mail file as well as off the internet but when I'm in Quicken 2008 program nothing prints. I've...
There is piece of software which is causing this problem you need to contact Quicken 2008 and get the setting changed to print , as the printer prints in other application ....
Jul 30, 2008 | Computers & Internet
Quicken 2009 Deluxe will not print on Vista 64 system on HP 5610 All-in-one printer - ran all the usual suspects about drivers, rebooting, selecting right printer, etc. etc. no luck. Seems Quicken does...
Me too. None of my printers worked and each time I tried Quicken crashed. But only quicken had this problem. Then I read this super simple fix:
  • Click Edit from the menu bar, and choose Preferences > Quicken Program.
  • Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  • Click OK.
  • Print checks.
At this location: http://tinyurl.com/moehn3
Worked like a charm. Go figure. Wasn't even a duplicate check number.
Aug 18, 2009 | Computers & Internet
Cannot open printer from Quicken 2001 Deluxe
Check intiut's website. There have been some problems with 64-bit Windows Vista. You didn't specify whether you have 32-bit or 64-bit operating system.
Aug 09, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
Inabilityy to print from QUicken 2008 under Vista 64-bit OS
I can only speak for my situation, which is Windows Vista Home Premium 64 bit with a HP7590 all in one printer. I had all the problems I read about, note I was only interested in printing "reports" from QUICKEN 2008 DELUXE.
I was able to use the Quicken PDF printer, but I just installed the HP 990C printer drive and found that report printing now works. I did delete the PDF printer before I installed the 990C, but I would guess that's not necessary.
HP considers the 990C a "generic" printer.
Hope this helps.
Aug 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Won't print checks or anything from quicken but does for every other program. All I get is "spooling" and then nothing.
It won't print you have to save the file on the desktop or in documents or anywhere away from the original and then try to print.all printers have issues with quicken deluxe they will not print from quicken deluxe unless it so happens b fluke
May 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Won't Print Quicken Checks- Canon MP620
Here is all I could find, as it is a compatiblity issue and not a repair issue. Hope this helps. You can also get on an online instant chat at www.hp.com and they may also have some answers for you.
HP has apparently released new printer drivers for some of their
> printers that will fix at least one print problem experienced by
> Quicken users.
> If you have an HP printer and are having problems printing from
> Quicken and you use 64 bit Vista, check this HP faq to see if there
> may be help for you.
> http://tinyurl.com/89ly3u
P.S. It appears that the fix will apply to more printers than are named in
the faq; The way I understand it, if there is a version 12 driver available
for your printer model, you probably should get it.
Apparently the list of printers to which the fix applies will be updated at
some point.
Don't forget to rate this 4 stars before you log out. If I can be of any help let me know.
Feb 01, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Quicken 2008 printing vista 64
There is an issue with Quicken 2007 and 2008 printing to many HP printers. Workarounds: 1) print to the Quicken PDF virtual printer, then print the resulting PDF file. or 2) Install a Deskjet 990 driver (using the add printer command) using the same port as the Officejet 7410 is installed.
Regards,
Bob HEadrick, MS MVP Printing/Imaging
Nov 02, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
