Question about Minolta EP1030/1030F CS/PRO Copier
Imaging unit warning led
Hi.
My copier has the led regarding the imaging unit always on, and stoped printing. This happens after 30000 pages.
I know that replacing the imaging unit should resolve this problem, but it´s a very expensive part and not easy to find where I live.
Is there any other way to solve this, like doing a reset to the imaging unit?
Thanks in advance.
  • 25 Answers
First enter into tech mode by pressing clear stop/exposure contol«/clear stop/exposure control» . Select the service mode function using the copy quantity and the zoom key and then press the start key.(The functions are shown in the order of d,c,A,and F.)
Now code c2 is(0) change to(1) press start.
Also to reset the counters, go code c6 and change it from (0) to (5) and all counters will be reset as soon as the machine is switched off and then on again.
good luck.
Posted on Oct 31, 2008
  • 3 Answers
Do Those Thing Which i told you please oppen counter cover on front panal then prees metar counter buton thann give program ( stop 0 stop 1 ) go from down key down and there is copy limit you just incres your copy limit it should be 30,000 make it 60,000 and make it of & on Than press panal reset Button
vip_umer4u@yahoo.com or call me +966557695755
Posted on Oct 24, 2008
Hi i just bought a second hand konica minolta c350 and when i print something it is notting enough clarity. please anybody can help me .
I would first starts by removing the Imaging units that are locked with blue levers below toner cartridges one by one for each colour and use the cleaning tool that is provided on the door (metal rod with handle and a pad on the opposite). When you pull the Imaging unit all the way out, you will see inside a long strip of LED and next to it on left hand side about a 1-2 cm another strip of MICRO LED Array. This is essentially yor print head and it has to be spotless clean. Use the rod and padded end to clean each of the arrays. This will give better sharpness and clarity to your prints. Then put Imaging Unit back in machine and pull the blue stick from the Imaging Unit out-in-out-in. The next step is to do Stabilisation and Gradation adjustments. This can be done in Service Mode. This should improve your printing. If it doesn't then you have either worn Imaging units _or_ Transfer Belt _or_ incorrect settings on Fuser or Fuser being worn.
Sep 29, 2016 | Konica Minolta Bizhub C350 Digital Copier,...
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
Dell Color Laser 1320c printer. The left side of page prints lighter than rest of page - color faded or lighter
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
Jun 09, 2010 | Dell 1320c Laser Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Imaging unit clp300
it is more likly that your OPC Image unit has print more than 25K +/-. that the printer will course the prompt.
press and hold the button of the printer for 5sec and let go. it will print out the supplier info of the printer life spend.
there is no way to reset the OPC count unless you work in Samsung.
Dec 05, 2008 | Samsung CLP 300 Laser Printer
Intermittent "Invalid Imaging Unit" messages
sounds like your printer engine is starting to take a long unhappy downturn..
Jun 16, 2008 | Samsung CLP-500 Laser Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Bizhub 350 color seperation
If the image units were the problem you would not be able to print the "perfect" first page.
Oct 02, 2007 | Office Equipment & Supplies
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
233 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
