Question about Toastess TT-415P 4-Slice Toaster
Another problem comes up....
Hi there, Thanks for your suggestion. However, after I opened the toaster cover up to fix the level bar problem, I encountered another problem! :( The handle didn't hold down when I pulled it down to toast! It maybe due to something wrong with the electric-magnetic holder of the handle but I don't know how to test it out where the error comes from. Since this's a relatively expensive toaster, I don't want to trash & buy a replacement. Please help!
  • 1,476 Answers
You definitely have a problem with the hold down circuit. You will need a DMM. If you don't have one they are fairly inexpensive now and with a little reading of the instructions you should be able to master their use. Look for a fusible resistor. It should be a small shiny canister, pointed on one end flat on the other, with metal leads on each end and inline on the wire to the hold down mechanism. Once you find this, with the DMM on resistance setting (continuity), check across the device. If the DMM says infinity, in other words it shows a 1 and the display never changes, this is your problem. Replace it with a new one. They protect the device from runaway heating and are set to open at predetermined temps. Replace it witht the same rated device. Available at most electronic stores. The rating should be in centigrade (such as 160, 180, ect). This should solve your problem. You cannot solder the thermal fuse in as solder will melt when the toaster gets hot. It must be crimped to the wire. Sounds like your almost there. Good luck.
Posted on Jul 20, 2006
SOURCE:
Lever won't stay down
They are disposable items these days, just buy a new one. They aren't made to be repaired.
Jun 10, 2015 | Cuisinart CPT-70 Classic Style 2-Slice...
INSTRUCTION to dismantle toaster
Hi benbecula. I cannot find a repair manual for you. The normal way top dismantle a toaster is to remove the screws beneath the toaster. They are usually self tapping screws that hold the polished stainless steel cover to the base. The knobs on the front of the toaster have to be prised off so the cover comes off. Make sure the toaster is removed from the power before attempting and examination or repair.
Hope this helps,
Michael
Jun 04, 2014 | Russell Hobbs 13767 4Slice Toaster
Why is the toaster dead? Is there an internal fuse that could be changed?
No, there is no fuse. There is a safety thermostat that detects when the toaster gets too hot and will shut it off. However, it is very unlikely that this has gone bad.
Most likely, there is a problem in the mechanical linkage that turns on an internal switch when the toaster bar is pushed down.
The other possibility, which is far less likely, is that the power cord has a break in it. Sometimes, if the toaster is moved around frequently, the power cord gets flexed too much and then breaks where the cord enters the power plug. Fixing this involves replacing the power plug. To diagnose this, you can carefully hold the power cord in slightly different positions and see if the toaster powers up in any position.
May 24, 2014 | Breville Kitchen Appliances - Others
How do I remove knob from Magimix 2-Slice Vision Toaster with out damaging it?
Do not try to just pull it off, you will likely damage difficult to repair parts.
On the underside remove 6 pozidrive screws 3 each end (one under the crumb tray)
Standing on its base - open the doors and remove 4x countersunk torx T10 screws, near the top, that screw from the inside into the end covers.
Now remove the opposite end to the knob, (in order to learn how it is held). Pull the bottom away from the base to the left, around 5 mm, and slide the whole end cover upwards, it unclips at the top. The other end is not so easy of course because of the knob. Release the cover, as before. It is possible - with the knob at the top, pull the bottom of the cover out 5mm and push hard to slide it upwards as before. The cover will release from its top mount. Then slide the cover all the way up, as far as the knob slot will allow. This will allow you see and have access to the back of the knob and the plastic clip that holds it in place. Stand the toaster on its base, with the end cover lifted up it is easy to put your hand inside the cover from the top and putting your thumb and forefinger around the bar you can grip the plastic hook and ease it downwards whilst you use your other hand to pull the knob and its firmly attached bar away. It will be necessary to wiggle the knob up and down whilst pulling it outwards. The bar surface is not flat, it has ridges that hold it in place quite well, even without the clip, hence the need to work it up and down. That's all there is to it! Hopefully you haven't broken the clip off, but if you have, don't worry you will still be able to use the toaster with little impact. The attached photo shows a close up of the knob and bar just separated from the mechanism. This should give an idea of what you are up against.
What a fantastically well made machine this is, a real pleasure to work on.
Oct 07, 2013 | Magimix 11535 Toaster
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
Need local service for my toaster
Hi Ordon,
Use the following link to find an estimate to repair your toaster.
http://www.fixya.com/Services.aspx?ctgid=161&zip=60601
Thanks.
Mar 31, 2008 | Dualit CTS4E 4-Slice Toaster
Light does not come on
see http://www.fixya.com/support/t153483-no_oven_but_still_toasts. the suggestion for thsi problem helped us withthe problem that you describe. Clean the contact after opening fromthe right side.
Jul 16, 2007 | Black & Decker TRO651 Toast-R-Oven Toaster...
No Oven but still Toasts
Never buy black & decker they don't supply parts they want you to rebuy the same junk over & over. its a shame this is what american companies have become buy japanese they last longer and make replacement parts.(I'm not unpatriotic just an informed consumer).
Jun 11, 2007 | Black & Decker CTO650 1500 Watts Toaster...
The level of the toaster doesn't lock
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Jul 17, 2006 | Toastess TT-415P 4-Slice Toaster
Toastess TT-415P 4-Slice Toaster Logo
142 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
Marvin
Marvin
Vincent_G
Vincent_G
ray gallant
ray gallant
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
