Question about Belkin Computers & Internet
Got a netgear router and belkin adaptor ...i dont even know what they are called...i really need some help to set up a wireless connection...i bought all the stuff and after a couple of failed attempts i left it alone but now i want to get it sorted out and i cant find the discs that came with the gear please rescue me thanks steph
    Master:
  • 538 Answers
Hmm..ok..maybe a little personal interaction?
send me a note here
pn4pm@yahoo.com
Posted on Oct 21, 2008
I have a Belkin wireless g gaming adapter (ethernet) that i use with my pc ps3 and xbox360 i use late last night woke up this morning to no connection! every compute rin the house works just fine but this...
I have the same problem, one moment it works, the next, "No Connection" I use my Belkin adaptor with my Hi Fi to stream Internet radio. I have reset both the adaptor and my router twice without any luck. Check that your Dad has not changed the security settings on the router. If so, you will need to change the the adaptor settings to match. This adaptor does not have the strongest signal, so this also may need repositioning. Good luck. I am about to try re do the settings. failing this i have run out of ideas
Jan 06, 2011 | Belkin F5D7330 802.11g/b Wireless Adapter
What to do after resetting routing? i dont have any manuals!!, its a second hand netgear router . Yesterday i had wireless in my house, today i couldnt get connection, and a friend reset the router, now...
On the router you will find a reset button. Hold it down for 30 seconds and then release it. Unplug the power to the router and plug it back in. Wait for 30 seconds. Now try to reconfigure the router.
To set up the router , you don't need manual or CD. You can do it manually.
First make sure that your computer is able to go online when you connect it directly to the modem. If that is working, then you just need to open the router set up change the settings of the router .
Click Here For Easy step by step instructions
Jan 05, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Netgear wireless adapter
In this case can you please tell me what is your wireless router and how may computer do you have so we can check if this is a problem with the wireless router or with the netgear wireless adapter. because if you only have 1 wireless computer so the problem here is with the wireless router we may need to change some wireless settings like the wireless channel .....
Nov 15, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Going wireless
Hi, sorry to hear you also having problems with the Belkin. I just bought exactly the same one and have just replaced it with a Netgear one as it didn`t work very well! Dont think the software is too good with Belkin but the encryption I used was TKIP (Belkin did work sometimes!) I also had a network key. sorry I cant help more-melanie
Sep 18, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
