Question about Bosch Kitchen Ranges
We have a Bosch fan oven. We had to turn off the electricity and when we switched it back on found that the oven does not work now. The clock is flashing, but I don't think we can set this as I have had problems with the clock for over a year, but that didn't stop the oven from working before.
  • sara99 Oct 21, 2008
    Thanks - while I was waiting for your reply, my husband managed to get the clock to stop flashing (though can't set the time properly as I explained before). This resulted in him being able to get the oven to work. This may be for the reason you gave in your response about putting the oven back to manual, but whatever the reason at least it is working!!
  • 414 Answers
It is possible that the after turning off the electricity the oven has reset in AUTO (timed cooking ) mode, try setting it back to MANUAL mode and try the oven again
Posted on Oct 21, 2008
Oven nor stove top works
Hi Myron,
I understand that you are having trouble with your oven, model# FGES3045KF, not working/heating, even though the display screen is showing everything to be working fine. I suggest to give your appliance a hard reset. You will do this by switching the circuit breaker off for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. The first thing you will need to do, is to set the time. You will do this by entering in the time and pressing start. Turn the oven on. If you are still having trouble with the oven not working/heating, I suggest you contact your local authorized technician to come and diagnose the oven, to see why it will not work correctly.
-Best Regards-
Jan 21, 2014 | Frigidaire FGES3045KF Gallery 30" Slide-In...
My clock on my Rangemaster Toledo 90 kept switching off last night whilst using it and ovens went off as well turned it back on twice and then the 3rd time it won't come back on. Its dual fuel so the gas...
Power from switchboard > oven circuit cabling > supply terminals of oven > high temp cutout > timer > multifunction switch.
usually the high temp, if so, check the cooling fan is working. Watch out for dodgy crimp connections on the wires (mechanical stripping can nick strands off the wire making a hot spot)
Oct 18, 2013 | Rangemaster Kitchen Ranges
Bosch HBN 70 Fan oven will not heat up to temperature, fan and light are working just no heat
99% of the time the problem will be a faulty element or burnt off wire at the element terminal. Best way is to pull the back cover off the oven and check the terminal connections. If these are okay put a set of test lamps across the terminals and you should have 240 volts. If you have 240 volts this tells you that the wiring is okay and the element is faulty. When you turn the oven setting to fan forced selection the power is delivered to the fan forced fan motor and the oven element at the same time. I am not familiar with this exact oven but most fan forced ovens have two fans. There is the fan at the back of the oven that comes on with the oven element and then the extractor fan in the cavity of the oven, which you cannot see but can hear. I trust you are talking about the fan forced oven fan which is generally at the back of the oven.
Feb 05, 2011 | Bosch Kitchen Ranges
My jennair burners ,fan and oven light work but
Replace the clock first(electric control) then test the oven it could be that it's why the oven does not work.
Jan 13, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Clock went out and now have a loud clicking sound even with electricty turn off.
Checked the fuse box and found no issue, but switched it on and off. Then replugged in the oven but still got the clicking sounds. However after again repushing the clock reset buttons the clock came back on and clicking stopped.
Jun 01, 2009 | Bosch Kitchen Ranges
MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Feb 06, 2009 | Bosch HEI7132 Titanium Electric Range
Whirlpool Electric Range Model RF379LXMT0 Power was off in house overnight and back on. Burners work but oven and controls for oven, timer and clock don't work.
I turned off the breaker switch for about 5 minutes
and then turned it back on. Now the oven, timer
and clock etc, are working again.
Thanks You
Aug 07, 2008 | Whirlpool Kitchen Ranges
Oven fan won't switch off
it sounds like the clock on the oven has been adjusted, if the clock has been adjust the fan will continue to "Cool Down" the oven for the period set on the clock, it is also a possibility tht the clock is faulty, is the clock digital or Analouge
Jan 30, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Error code
Try unplugging or turning off the breaker for 30 mins then plug it back in and see if you still have the 160. I'm surprised that it doesn't have an F anywhere in the code. How old is the oven. Could some of the lights on the control be out. they are LED's and sometime they do burn out. I'm thinking this could be an F06 code which could mean anything from a power surge (clock) and needs to be reset (like I said by switching of the breakers or unplugging) to an EOC (Electronic Oven Control) failure. By switching off the oven and waiting about 30 mins. if it doesn't come back on it will be the EOC. make sure the LED (light emitting diodes) aren't out on the control making you
Dec 20, 2007 | Bosch HDI7282 Dual Fuel (Electric and Gas)...
Clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
Aug 11, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Kitchen Ranges Logo
908 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
