no VIN told
no country told
no year told
no kind of transmission told ,
manual or automatic
the only clue is 6th gear,
my 2008 jeep has a 6speed
manual transmission
SEE?
let me guess it is a M./T box and has manual foot clutch
and the clutch slips.
seems your shop in town is not so good.
top cause of gears not selecting is the gear shifter linkage is all messed up. (damaged, worn, or adjusted wrong)
or the
main clutch is dragging (bad) or slipping worse.
any shop that knows M/t can diagnose it, but not yours.
the old 6sp mt box has side lever shift links up to 1995
then later the
Eaton Fuller FS6406A 6 speed box?2004 up??>?? no year truck told, why must any helper beg fo the year.
with classical. top lever shift and big knob end
the bottom of the classical lever. has tip and this tip can be plastic to stop noise but wears out fast and the H pattern fails to work this is super common super easy cheap fix.
even a $10 fix.
Eaton fix easy, nothing ever was so easy this failure
see the stick?
remove it and see the tip is damaged.
bingo.will not pick gears in the H pattern, or is RAndom
BOX GOOD
CLUTCH GOOD
SHIFT TIP NOT GOOD. A DIRT CHEAP PART.
