Question about Tally Line Matrix T6215 Printer
Tally T6218 show paper out even if there is paper. what is the solution
Tally paper out even thou there is paper
  • bengnza Apr 28, 2009
    I have a similar problem with my tally. It keeps bringing Paper Out on LED after it is powered up even if there is paper. i have tried to enter Tech access mode. after Tech access mode is ON i am not able to enter the menu or clear the error even if i go out of tech access mode. please help
Have to enable techmode (go offline and hold the line feed and enter button for three seconds)
then go into the test menu and do the fault override and turn off paper out sensor and then must calibrate the paper out sensor by checking and verifying voltage with paper in and paper out, this is done on the control panel.
Posted on Jan 14, 2009
Hey dear!
how can i go into the test menu? i can't enter the menu and the config. when i press LF with ENTER for about 3-4seconds it shows offline. and then what next? i can't do anything further,. please help me?
Posted on Aug 10, 2010
4 Suggested Answers
  • 114 Answers
SOURCE: My Tally T6218 gives the
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
Posted on Jan 30, 2009
LineMatrix
  • 34 Answers
SOURCE: Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Posted on Apr 26, 2010
LineMatrix
  • 34 Answers
SOURCE: paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Posted on Oct 15, 2011
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Hammer Voltage 1
Hammer Voltage 2
Corrective Action:
Apr 05, 2010 | Tally T6218 Matrix Printer
Tally odbc
Whatever reports you want ot convert in Excel there is a command in Tally to Export File. you can select excel in export configuaratin. Even .CSV formats can also be opened in excel.
To Export File in Excel .. In tally Goto that report and press ALT+E or look for "Export Command on Tally Toolbar or left panel.
Mar 23, 2010 | Tally T6218 Matrix Printer
Error messege
Check paper out switch behind tractor assembly. It may be bent and also make sure that the green bar (if used) is installed carrectly between the tractors.
Jan 05, 2009 | Tally T6218 Matrix Printer
Error messege in printer tally T6218 (paper out) what is soultion
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
TALLY 6218
Hopefully, you have paper in there!! LOL! Some times if the paper is not inserted correctly, the printer won't reqcognise that there is paper there, just pull it out and reinsert it, sometimes you have to do it maore than once.
Error in eject page
dont use LF use FF to forward a form. if you use LF then set the topper form again.
Feb 03, 2008 | Tally T6218 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Paper motion fault
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally Line Matrix T6215 Printer Logo
813 people viewed this question
Top Tally Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
