Question about Garmin zumo 550 GPS Receiver
Can you get mapsource to work on linux
Hi anybody out there now how to ge mapsource to work on linux
    Scholar:
  • 174 Answers
I don't think so, They only cater for Apple and Windows at Garmin.
Posted on Oct 27, 2008
Mapsource doesn't open.
usually by installing the maps!
Jun 23, 2009 | Garmin nuvi 200W GPS Receiver
Mapsource not recognizing Garmin type files
.img files do not open directly in Mapsource. You will need one of the many freewares available on the net. I use MapSetToolKit. The file is available at http://cypherman1.googlepages.com/. You can find out how to use this software from http://cypherman1.googlepages.com/intruction_en.
Jan 19, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin gps60 connected to PC
You have the USB cable but what software? Have you got the MapSource CD? If not, there's a free and legal workaround. Download the free Garmin Training Center (from Garmin site), open it to check it works, close it then download the Mapsource update file, also from Garmin site. You'll now have MapSource and can uninstall Training Center. You'll need maps though - depending where you are there's some free maps otherwise get a Garmin map to make it easier to plan trips.
Oct 26, 2008 | Garmin 60 GPS Receiver
Linux on LG e200 or r200
i have a linux (gentoo 2008.1, kernel 2.6.25) on lg e200, all devices work fine,
Jul 14, 2008 | PC Chips M955G Motherboard
Best way to find out is to download a live CD. If you're planning on running Debian, using the Ubuntu Live CD should demonstrate whether current Debian works on your system.
It may not auto-configure all devices in Live CD - don't be surprised if you find that USB headset or WIFI card doesn't work on boot - but at least it will give you a clear idea of whether the system works or not on your machine.
Ubuntu's 8.10 (Intrepid Ibex) is reported to boot on the e200 in Live CD mode; you need to use "safe" graphics mode to do the install (after which you can install the correct video drivers).
Enjoy your new OS!
Jul 13, 2008 | LG Electronics 16x DVD and 48x CD-ROM...
I have lost my Mapsource Setup cd for my Garmin GPS
  1. Download MapSource software updater from Garmin. The version as of December 4, 2007 is 6.13.6, and the trick also works on Map Source version 6.13.5.
  2. Unpack or extract the content of MapSource_6136.exe
    downloaded using WinRAR.
  3. From the extracted files, run MAIN.msi.
  4. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
  5. Garmin MapSource now installed.
Feb 02, 2008 | Garmin eTrex Vista GPS Receiver
Can not unlock mapsource due to lost unlock certificate
Dear friend, excuse my mistakes in writting, since long ago I dont write.
Download this file:http://chilestreets2007.googlepages.com/archivos
todas las partes del Archivo Chilestreets 2007 working.rar
A.- Instalar Mapsource Chile Streets Setup.exe de la carpeta Mapsource + ChileStreets
B.- Usar el serial contenido en la carpeta Mapsource + ChileStreets\serial
C.- Conectar el dispositivo GPS
1.- Obtener el ID del dispositivo Garmin: es un un número de 10 dígitos.
- Iniciar Mapsource desde el PC
- Conectar el GPS
- Ir a Utilities, Get Unti ID.
2.- Abrir Keygen v1.3.exe
- Ingresar el número de 10 dígitos del ID de dipositivo en el primer espacio en blanco (Enter you Unit ID here:)
- En el cuadro Select Map Product:, selecciona de la lista <Custom Mapset>
- En la ventana emergente anota 724 para el MapID code.(ok) el código varía para otros mapas, este es para el Chile Streets.
- Haz click en el botón "Generate" de más abajo. Con esto se crea el código de desbloqueo que se ingresa en el Mapsource. (No cierres esta ventana)
3.- Abrir la utilidad de desbloqueo de mapas del Mapsource.(CTRL+U):
- Haz click en siguiente.
- Selecciona la opción "Si, tengo un código de desbloqueo de 25 caracteres" (Siguiente)
- Selecciona la opción "tengo un código de desbloqueo de 25 carcateres; lo escribiré" (siguiente)
- Introduce el código suministrado en el paso 2. Puedes anotar un comentario de recordatorio en el recuadro inferior pra saber que unidad es la que tiene el mapa desbloqueado. (siguiente)
- Selecciona la opción "No, me registraré mas adelante" (siguiente)
- Selecciona "Sí" en la ventana emergente.
- Selecciona No, he terminado si no quieres instalar más códigos. (siguiente)
4.- Transfiere los mapas al dispositivo o a la tarjeta SD, Mapsource transfiere los códigos en forma automática.
Please translate this procedure. The important matter for you is that you now have mapsource active and with de Keygen v1.3, you can unlock a lots of maps. Please don´t publish this solution, because a lots of people would not have access in the future to this program.
Nov 26, 2007 | Garmin Touch Screen GPS Receiver
Garmin Windows Vista Issue
I now this issue, and it's quite easy to work around, right mouse click on the executable and select run as administrator.
Aug 28, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
243 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
