Question about Canon Office Equipment & Supplies
Pink prints where grey should be
I am printing photos that have a grey border and it prints with pink in the grey, I can not go fully grey scale because there are other colors that print great,, I'm using canon mx310
  • ajlacour27 Oct 21, 2008
    yes and I just recentlyended the problem, I changed my color setting to cmyk in photoshop instead of rgb, I did this after reading a article about the diffrence in the two, So far doing that has fixed the problem,,
    Genius:
  • 1,250 Answers
Have you clean the cartridge
Posted on Oct 21, 2008
Horizontal pink lines on print every inch or so.
Do the magenta lines go outside the picture into the white border? If so, the print head has gone bad, and the cost to replace a print head is more than a new printer.
May 12, 2015 | Epson Stylus Photo PX720WD A4 All-in-One...
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Why print out is grayscale? my catridge is full
The printer software has an option "print in colour" versus "print in grey-scale". Reset the option.
Jun 11, 2010 | HP DeskJet 3940 InkJet Photo Printer
Cannot load template to Sony UP-CR10L, how can I copy the custom made tempalte to CR10L?
You need to copy the border you created in the border creater software to a border folder on you computer that you have created to store you borders in.There is a folder on the CD that came with the machine that
I would suggest you copy to your hardrive as this will need to then be copied to a compact flash card that is then installed in the expansion slot on the inside of the ribbon carrier door.If you save your new border to the folder on you hardive you can always back it up at anytime.If you
print different sizes you will need to create a border for each size of print. Once you have installed the card in the machine switch it on and
go to the print option screen and you will see the border ikon is not greyed out but now active simply select this option and the the border you require.Then it should print.
Sep 18, 2009 | Sony SnapLab UP-CR10L Digital Photo...
Can't find program for borderless printing
You need to really defining "Border-less Printing". Are you speaking of printing border-less photos? Or do you mean border-less documents.
Border less photos are usually set up in the printer's driver, providing that the printer's hardware allows this function. Some printers, especially older models, cannot print to the edge of a page by design.
Don
Aug 16, 2009 | Brother MFC 6490CW InkJet Printer
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Prints off-center
that's a scaling issue from the application you're using. the printer is not the situation?
May 20, 2008 | HP PhotoSmart C4280 Laser Printer
Mac leopard and ip4500
Have you tried using different software for your printing.
Something that will give you more scope and resolution Options.
Such As Paint Shop Pro et,c. Or try and locate the default program for the hardware. Also try opening and re-saving the photos in a different Format i.e J-peg Or Bitmap. The canon is probably used to it,s own specific format. Finally is to check the paper-scaling, you,ll have to do various test prints at allocated sizes, to ensure the printers doing the scaling that it should be.
Hope this is helpful for you.
Regards Mike @ Compurepair.
Feb 22, 2008 | Canon iP4500 Photo Printer
C88 printing in grey instead of the color
In the Print dialog, go to 'Properties.' Screw around in there for a bit.
Oct 17, 2007 | Epson Stylus C88 InkJet Photo Printer
610 people viewed this question
old marine
old marine
