Question about D-Link DES-1024D Express EtherNetwork 24-Port 10/100 Switch (S2299467)
D-Link DES-1024D problem
My switch used to work fine, but the other day it stopped working. I could only have Internet connection on 1 pc, usually the first 1 I turn on, but the other pc's can't connect to the Internet. What could be the problem & how do I solve this/
  • khalido24 Mar 31, 2009
    My switch used to work fine, but the last day it stopped working.there is no power >
  • tanvierahmed
    tanvierahmed May 11, 2010
    are you useing DSL router?
    If yes
    You are useing DHCP to provide IPs to the systems?
3 Suggested Answers
  • 3 Answers
SOURCE: D-Link DES 1024D
There is no configuration on the switch, this is a dumb layer 2 device. Plug in you PC's etc.. and go. The switch will auto detect the speed and duplex of the device connected to it.
Posted on Jan 08, 2009
theBerto
  • 12 Answers
SOURCE: link/act LED of DES-1024D switch
The ethernet cable is probably damaged. If it is not... is the switch plugged in? Does it power on? Is the other end of the ethernet cable plugged into a live host?
Posted on Jul 31, 2009
  • 7993 Answers
SOURCE: My switch used to work fine,D-link DES 1024D
I suggest you reconfigure you network. Maybe your configuration authorizes only one IP adress on the network.
Try to reset your router to defaults to see if that solve your problem. After that you will have to reconfigure the router.
Hope it helps.
Posted on Sep 11, 2009
My d-link des-1024d fast ethernet switch is hanging problam
My First option is to restore the switch to factory default once and then reconfigure the switch.
What is the IOS running on the DES-1024D ?
Are you getting any error message in the log when the switch is hanging. ( through console connection).
Second Option is to upgrade the IOS to a recent one.
Dec 06, 2010 | D-Link DES-1024D Express EtherNetwork...
Some loose contact it seems??? sometime able to connect internet and sometimes not possible?? wat is the reason???
D-Link 1024D performace drops when it gets heated.. Thermal problem.. switch off this equipment for few minutes and try.. keep this equipment in proper ventilation
Jun 01, 2010 | D-Link DES 1024D (DES-1024D) 24x10/100...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Hope it helps.
Sep 11, 2009 | D-Link DES-1024D Express EtherNetwork...
I connected an ethernet cable to the DES-1024D switch, but the link/act LED didn't light
Is the switch powered up?
is the Ethernet cable connected to a working/powered/enabled NIC?
Jun 10, 2009 | D-Link DES-1024D Express EtherNetwork...
Link/act LED of DES-1024D switch
Jun 08, 2009 | D-Link DES-1024D Express EtherNetwork...
D-Link DES-1024D Express EtherNetwork 24-Port 10/100 Switch (S2299467) Logo
706 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
