Question about Microsoft Windows 98 for PC
Argie hlo!!! can i help me hw to create a java code so that i learn hw to expert wth hem
  • 340 Answers
You posted this under Windows98, - if this is your software, then here is the URL you need:
http://www.fivesign.com/downloads/program/Java-Code-Library_44637_118_download.html
Please vote if this was helpful .-)
/Teis
Posted on Nov 29, 2008
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    /Teis
Hw to fix ec 2188 crt tv 21" comin out wth blck n white pics
Hw to fix ec 2188 crt tv 21" comin out wth blck n white pics ...
www.fixya.com/.../t26080626-hw_fix_ec_2188_crt_tv_21_comin_out_...
3 hours ago - Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic'
Feb 03, 2016 | Televison & Video
Bc sensor error
change your bar code sensor
May 06, 2014 | Printronix P7005 Matrix Printer
Am having trouble installing Java 7 in Internet Expoler 9. When I do install it, it says that it has been installed, but it doesn't work on tet pages, even in compatibility mode. I'm an expert user, b
I am not an expert user so I don't know much about this but needing to contact a forum to solve a problem I learned the Java programme and Java Script that causes problems when it doesn't work are two different things.
Java Script, they told me, is not a standalone programme but a part of the Windows operating system. I can't remember the details but I had to open the control panel and somewhere in there had to "enable script".
I hope this helps.
Sep 14, 2017 | Microsoft 7 Computers & Internet
I wanna to learn java and oop programming
The Java provides a self-guided introduction to Java programming, starting with the basics and covering all the core concepts you need to know to become a productive Java developer. This series is technical, with plenty of code examples to help you grasp the concepts as we go along. Benchfolks is one of the best place to learn Java,they guide you and helps you too get a job , Benchfolks guide you for java certification training.for more details you can visit this website:http://e-learning.benchfolks.com/online-training-java-certification-courses.html
Sep 03, 2011 | Computers & Internet
How to do vb.net framework ??
You need Visual Studio from Microsoft. Inside this visual Rapid Application Development (RAD) tools, you can use c++, c#, or basic language. It is lot of learning to become programmer.
You can find SharpDevelop free programing studio if you want to learn more. With this program, you will need .NET packages on your computer. It is like JAVA from Sun (Oracle). It is copy from Microsoft of JAVA ideas. Like free NetBeans IDE for JAVA development.
Inside studio you will have option for create New project. It can be grafical with graphical designer for draw some button, text input frame ... You will have properties for this objects, and possibility to write programming code. It is lot of learning to do real application. When you write some application you can compile it to exe output.
Visual Basic is only simplest part of this technology. C# (C-sharp) need more learning, and C++ is hardest thing.
Aug 26, 2011 | Computers & Internet
I need a mini project in php or java
Hi piyushsharma,
What you need is to outsource this job, so the site I would recommend is freelancer.com You can post your project for free as a trial, explain what you need, select the PHP and Java categories and then let the programmers bid. You can chat with them and select a winner to create your mini-project.
Hope this helps, wbwTeam
Feb 05, 2010 | Monte Carlo 5KC48JG Java Rattan / Grecian...
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
I WANNA MAKE SOFTWARE OF MOBILES
it should be done by some tool box like ufs,infinity
Dec 03, 2008 | Nokia N72 Cellular Phone
Java programming
I ll give you some reference book names for core java they are the best,
1)Head First Java by Kathy Sierra & Bert Bates
2)SCJP 5.0 by Kathy Sierra & Bert Bates
the first one is the best for the beginners read it before you go for any other
good luck
Aug 14, 2008 | Sun Java Programming Language (cdj-275)
About tally
Learn Tally 7.2, Tally 8.1, Tally 9 @ your home.
Fee Rs.2000 PrePaid (Rs. 500 extra for study material) (weekly 3 days class, 1 hour duration / total 9 class)
Ph : 9341-202004
E-mail : shekhar202004@rediffmail.com
Sep 03, 2007 | Tally Line Matrix T6050 Printer
Microsoft Windows 98 for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
