With brand new batteries and a brand new Sony Memory Stick PRO MagicGate, when I turn on my camera, I get a "No Memory Stick" on the screen. Can't take pictures, and isn't recognized on the pc. I've used ths camera for years, and now its not working. It has not been dropped, I've already reset it, changed the batteries. I've even tried to format the memory stick but it doesn't even recognize that there's one in the camera, so that's not an option. I've even tried other memory sticks that I've used many other times and it still does not recognize the memory stick is in the camera. Any suggestions?
Comments:
Jul 20, 2006
- This happens with ANY memory stick I insert....even ones I have successfully used in the past.
-   I have a sont cyber shot. I am on my third memoy card. I have sent the camera into sony twice now. I place a card in the camera and it says reinstall memory stick when there is one in there. The PC can read it and show the pictures but it does not work in the camera,,,,HELP!!!
-   stbahorn
Aug 01, 2008
-   Everytime I turn the camera on, it says that the memory is full, when there isn't even any pictures.-   chel_shel
Dec 22, 2007
-   iMy memory stick is not recognized by my computer. First it was recognized for short time, but it disappeared. Now i cant see it, even if I reinstalled the operating system. His light doesn't flash. 've tried all the USB ports. Help!-   gpricope
Due to the length of the memory stick it rarely causes bent pins sideways but they can over a long period lose their tension and fail to make contact with the memory. Also, more commonly they can tend to get a build up of dirt on them.
Try using an old memory stick and quickly push the stick in and out of the camera as fast as you can and do this for about 15 to 20 times (with the camera off of course) this should clean any gunk built up on the contacts. Now switch on and use the new stick to see if it's working. If not try the exercise again.
If it still doesn't work try sticking 2 layers of sticky tape to the front (the side opposite the gold contacts)Run the tape from the bottom (the contact end) to the top. Running it to the top will ensure it comes out with the stick when you eject it and it doesn't stay inside causing problems. Doing this will marginally increase the size of the stick and put a little more pressure on the contacts. Just nake sure the sticky tape comes nowhere near touching the stick's contacts as this will tend to make them pick up dirt. Also this trick is only to see if it's you camera's contacts have lost tension, its not meant as a permanent fix.
If neither of these tricks work I'm afraid it's a trip to the camera hospital.
normally when a memory stick is inserted the wrong way or in a speed, the contacts pins inside the cmera tends to bend. If the camera is not sensing the stick this may the problem.
All the other suggestions are great advice. I went all through them and then remembered what happened with the camera a couple of years ago. The camera sometimes seems to be sensitive to a lowish charge. Even if the charge is sufficient to get the machine starting up as nornal sometimes it seems to need batteries with a really good level of charge, perhaps because the contacts are damp or dirty. I found that my battery charger wasn't working properly and as soon as I borrowed someone elses charger it all started working instantly.
Sony Cyber-shot DSC-P72 digital camera with 3.2 mega pixils The lens stuck. Lens goes in and out...
(More)
Sony Cyber-shot DSC-P72 digital camera with 3.2 mega pixils The lens stuck. Lens goes in and out like it is supposed to, but the lens end shutters get stuck and will not close. The culprit is the pop that got spilled on it. I need to know how to get the end bezel off of the lens so that I can clean it.
Cybershot W150, when I turn it on, the lens extends...the shutter opens...but the LCD screen does...
(More)
Cybershot W150, when I turn it on, the lens extends...the shutter opens...but the LCD screen does not come on. Then the lens starts retracting and extending about 3 times and the camera shuts down. I can view and down load the photos that were on the camera, but the shutter button does not function.
I have p72 camera since 2004. Nowadays, when it is powered up, i have to re-enter the date. Is it a...
(More)
I have p72 camera since 2004. Nowadays, when it is powered up, i have to re-enter the date. Is it a back-up battery problem? If it is, how can i replace it? And when i leave the batteries inside, in a couple of days, the batteries discharge, it this normal? This is always the same from the beginning so i removed the batteries all the time. Thanks from now. Erdogan Demircan
