Question about Canon PIXMA iP5300 InkJet Photo Printer
Problem picking up disc to print and also photos
My printer is not printing on a disc. You see it go in and the rollers just push it out and the error message comes up saying there is no disc tray or no disc. But there is!!! Cleaned rollers but nothing seems to help.
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
  • 5 Answers
SOURCE: wont print
I just wanted to add a little note to this issue. I had the same problem, except the tiny lever on the output tray microswitch was broken off, so there was no way for me to lock the switch in position with glue (or tape as suggested above). So instead, I bent the two leads for the switch as close together as possible using needlenose pliers and used a soldering pencil to melt the existing solder and fuse the leads together, effectively closing the circuit permanently. (I could also have just disconnected the two wires from the switch and soldered them together.) I now have a functioning printer.
Posted on Apr 06, 2008
ydja
  • 3 Answers
SOURCE: horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Posted on Jan 20, 2009
SOURCE: Print head is not installed. Install Print Head
Installed 2 new factory spec. print cartriges.
Posted on Feb 13, 2009
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
Rollers won't pick up photo paper.
Hi I would suggest you to try once again by putting the shiny side up and print it again, some time even if the pages get stick with each other than also the printer wont take paper in. so try one more time and do reply if you still have the same problem or nay other.
Naiven.
May 31, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Error message Tray1 Load LTR
This meens a printjob was send to print on "letter" papersize, all though there is another papersize selected in tray 1.
Push the select button several times and the machine will print this job
Jul 11, 2009 | Lexmark C500n Laser Printer
Can print A4 but not photo paper
It looks like you have a problem with the pick up roller....try removing the roller and washing it with water dry properly and insert it back to place ..this is temporary fix.....and mite not work 2..u need to replace this roller....if it continues to trouble you
Oct 31, 2008 | HP PSC 1410 All-In-One InkJet Printer
Printer busy or error
So are you saying that the printer looks like it's about to print but then gives you a red error light? If so I think I had the same problem. It is to do with a faulty part (very cheap). The part is a kind of roller that picks up the paper. In some CLP-300s the rollers surface is too coarse, thus not picking up enough paper.
I had a service department change it for me, did it in 5 mins.
Hope this helps.
Jul 25, 2008 | Samsung CLP 300 Laser Printer
Paper sent through without printing
You should try cleaning the pick up roller. It may be your paper has quite a dusty surface and this will cling to the pick up roller making it less grippy. When the paper is fed it may not make the first sensor in the expected time and thus creates the error. Get a service manual to show you how to get a t the pick up roiller so you can remove and clean it. You can get Platen Cleaner from many web sites and it is specifically formulated to regain friction os such rollers. Try either: http://wwwTheServiceManualShop.com or http://mikeburton.tradebit.com/ for a service manual
Apr 11, 2007 | Epson Stylus Photo R2400 InkJet Printer
Canon PIXMA iP5300 InkJet Photo Printer Logo
old marine
old marine
