Question about RCA D52W19 52" Rear Projection Television
New screen needed
Hi i have broken my screen on LG projection tv model number 52SZ8R.. dose anyone know where i can get one thanx!!
    Genius:
  • 1,030 Answers
Try union electronics
Posted on Oct 21, 2008
Hello, I have a LG rear projection tv model number LG 52SZ8R-ZA that has recently stopped working at 100%. The screen appears alot duller as though the brightness has been turned right down. Is the problem...
Hello, You can get better prices for bulbs on the Internet. I went through this problem with my set.
Sometimes there is an upgrade in bulb Wattage on an individual basis by Model. What you may be having problems with is a system called a "Light Engine". This assembly has the power module and a spinning part called a "Light Wheel".
Your problem then can be from any of these devices. Your old bulb could have a dark spot (As normal light bulbs can develop), a weak power module, or a light wheel not spinning at the correct RPM for clarity.
You can take a chance and try a new bulb yourself or call for a Technician to give you either a "Convergence Set-up" or Evaluation and Repair estimate.
I learned about the insides of these TV's from the Front-Projectors and my own Rear-Projectors which had Warranty Recalls. So I have seen Messed-up and know what it looks like and somewhat about the causes and cures.
If you are getting a Convergence service, you may want to get the Estimate, then install a new bulb through the Internet, and then get it all set up fresh with the new bulb.
Oct 11, 2011 | LG Televison & Video
My LG projection tv (serial number 52sx4d-ub) won't turn on, an orange light flashes then turns red. How do I know if I need to change the bulb or the ballast? And how much does it cost to change the...
Orange blinking light under a small picture of a light bulb? Then turns to a red light?
Sounds like the same problem I had when I picked up my LG 52SZ8R. After replacing the lamp the TV ran fine.
Easiest way to see if the lamp is the problem is to take it out, and look at the peice of wire in the globe as you would an old light globe.
If you need help, download the following manual, and look at page 9.
http://www.jordansmanuals.com/ServiceManuals/LG/TV/PROJECTION/62SX4R/62SX4R%20Service%20Manual.pdf
If it does come down to you needing to replace the ballast contact: http://www.statewideapp.com.au/index.php?selectedContent=1188381775
They should be able to give you a quote and part number, if you don't like their quote you can always use the part number to search for one thats cheaper.
Mar 07, 2011 | LG 52SX4D 52" HDTV
Is my lg 52sz8r able to go 3d as in the menu it
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Apr 05, 2010 | LG RU-52SZ51D 52" Rear Projection...
I have a LG 52 inch model number 52SZ8R-TB but no longer have the manual. There are 3 red LED's on the front panel, the right one flashes red whenever I try to turn the TV on. Does anyone know what this...
YOU CAN REVIEW THE MANUAL FROM THE FOLLOWING LINK.
http://www.lge.com/au/support/product/support-product-profile.jsp?customerModelCode=52SZ8R-TB&initialTab=documents&targetPage=support-product-profile
Dec 11, 2009 | Cars & Trucks
How do I reset the lamp life on my LG 52SZ8R.
hold the mute on the remote and press enter on the tv and it will come up in the menu for you to reset
Jul 08, 2009 | Televison & Video
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Jun 15, 2009 | LG Televison & Video
Broken plasma screen
You need your Tv product code wich is located in the back of the TV next to the serial number.
you can get one directly from LG ($500-$800) or you can try EBAY, look for a TV non working with a good panel, it doesn´t matter why is not working as long as the panel is in good condition, the price range is wide but you can get one for $150-$250.
And no you can not use any 42" plasma.
May 16, 2009 | LG 42PC5D Television
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
