Question about Admiral Washing Machines
I can stop the spin with my hand so the clothes are still wet after the spin. My washer is a admiral model #au 40003 no belt 2004.
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SOURCE: ALW480DAW Washer Doesn't spin
access panel in frount, 2 screws to take out. if you washer is not spinning but washes try the tension pulley is not tight enough. to cured problem of not spinning if tension is not tight. check if the plastic pulley is turning if not get it loose and put greases on it. there should be a metal sleeve fasten in the pulley. but if it is rusted to the other shaft it spins on you will never know it was to be fasten in the plastic pulley. i broke them lose and greased tighten the spring and it should work good. time to time might want to grease it.
for the other person if you machine sounds like it is winding to go in to outer space, it most likely the bearings. they are 100 each and there are 2 of them. plus seals. i used mine for a year before i locked up, if you like the performances of that machine get it fixed. the $1200 front loader i just bought went back and the old AMANA is getting fixed.
Posted on Jun 14, 2008
SOURCE: replacing spin belt whirlpool clothes washer
There is indeed a drive belt to the imperial 70. Problem more likely is in the 'wig-wag' unit that engages and disengages the spin clutch and the agitator drive
Posted on Sep 10, 2008
  • 7 Answers
SOURCE: MY ADMIRAL WASHER WONT SPIN FAST ENOUGH..IT DOES SPIN BUT WHEN IT STOPS THE CLOTHES ARE STILL DRIPPING WET
Sounds like a whirlpool or inglis type belt drive with a loose belt or bad basketdrive[clutch].
Could be the set screw backed out on the basket, thats a pretty common problem.
I'd need a model number to know who made it though.
Posted on May 19, 2009
  • 155 Answers
SOURCE: slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Posted on Sep 02, 2009
MY WASHER SPINS AND DRAINS THE WATER BUT MY CLOTHES ARE STILL WET
are you sure that its spinning as this is a common problem with wet clothes. When the cycle is complete the clothes should be wrapped around the bottom of tub not just lying there,
Sep 26, 2011 | Admiral AW22 Top Load Washer
Our washing machine spins, but it doesn't spin our clothes out. Everything comes out still very wet, even more so if it is a heavier load. It almost seems like it is being slowed down by something but we...
Change the belt, a worn belt causes the machine to spin slower.
Tilt the machine back and the belt is accessible underneath the machine, simply remove and replace no tools required.
Dec 26, 2009 | Admiral AW22 Top Load Washer
Slow spinning wet clothes
Sep 02, 2009 | Admiral AW22 Top Load Washer
May 19, 2009 | Admiral AW22 Top Load Washer
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Admiral is not spinninng
i would say the simple soulation to this is get the main belt tightened.sounds loose???.hope this helps.adrian
Jan 31, 2009 | Admiral AW22 Top Load Washer
Nov 09, 2007 | Admiral AAV7000A
Washing Machines Logo
44 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De GO PATS
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
