IBM Selectric III typewriter: Spacebar when touched for one space often fires away as though it is being held down.
Spacebar when touched for one space often fires away as though it is being held down. Am technically competent - could this be a DIY fix?
  • Trevor Preece Nov 20, 2008
    Clearly I'm near a solution, but am not too sure about "the R. black duat cover". I presume "duat" is meant to be "dust", but R.? Rear? No evidence of a rear dust cover - just the lift-up front one. And it's not black. Maybe the bottom black baseplate?If you have a moment to clarify I'd be grateful.
    Perhaps I'd better get one of the manuals advertised on ebay in USA?
  • 3,594 Answers
Remove the R. black duat cover. Get some WD40 and spray the cam cluster and the related parts espesially the pivit points of the arms front and rear of the cams. They gum up and cause this problem.
DickyO
Posted on Oct 23, 2008
Space bar on sylectric 2 ibm typewriter is not moving the type
There are a few things that can cause your spacebar to not move the carrier. Do you hear any sound when you press on the bar? There are adjustment that may need to be made to the machine or perhaps there is something sticking in the mechanism. Unfortunately you mey not be able to fix this yourself as these machines need a technician to properly repair and service the machine.
Feb 15, 2015 | IBM Correcting Selectric II
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
IBM 196C (mkIII), UK model - spacebar triggers multiple spaces.
I'm not sure what a196C is but if it is a selectric (ball machine) there isn't much anything you can hurt with WD40, if it it is a typebar machine be very careful.
DickyO
Apr 05, 2010 | IBM Office Equipment & Supplies
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
I need to know how to install a ribbon on an IBM Selectric III typewriter.
Go to lexmark.com and click your way to publications there you can get instructions and pictures of installation. Remember there are 2 different ribbons for Selectric III,s.
DickyO
Sep 19, 2009 | IBM Office Equipment & Supplies
The keys on my IBM Selectric III typewriter are frozen....is there anything I can do ???
First; depress the tab key. If that unlocks it, then you need a return clutch or torque spring replaced. Does the spacebar or tab key work? Sometimes you can gently press everykey on the keyboard and eventually one will release and unlock.
May 14, 2009 | Office Equipment & Supplies
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
191 people viewed this question
jasbo
jasbo
