Question about Panasonic Televison & Video
I have a TX-36PG50 TV set bought on the 23/09/2001. I have no sound at all. The fault started some weeks ago and when you turned the set on there would be no sound then maybe after a couple of hours the sond suddenly can on. This happened for a couple of wees now there is no sound at all. The picture is fine and we have a second TV in the corner which is picking up the sound for now. Any help would be appreciated - also do you konow where is the nearest Panasonic Authorised Repair agent if you are unable to help bt email. Many thanks, Mr Tony Young
    Top Expert:
  • Panasonic Master
  • 74,999 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 23, 2017
  • 192 Answers
SOURCE: PT-43LC14 No Picture, chirping sound when turned on
Begfore calling a servicer, pull the bulb out and check if it is broken. The chirping you hear could be the ballast trying to fire the lamp. If it is blown, make sure you clean the vent filters when replacing it.
Posted on Dec 12, 2006
SOURCE: Panasonic pt-52lcx65 picture problem
Have a sears technician come over ,call them and set up an appointment, they are the best techs out there for tv issues, they will come out even if you did not buy the tv from them. Most of the Sears tv techs come from Philips which closed down their tech shop a while back. It sounds like you have dirty or faulty fans on your board. please advice.
Posted on Sep 24, 2007
  • 1153 Answers
SOURCE: Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info
Posted on Dec 10, 2007
  • 8617 Answers
SOURCE: power problem
How many blinks is it doing? It has a built in self diagnosis code that it will blink. Pause a second then blink again. Count the blinks then let me know.
Posted on Jan 18, 2008
  • 86 Answers
SOURCE: panasonic 47 inch rear projection
Have you checked the lamps. Rear projection TV's have bright lamps, that can burn out. If you have had this TV for a while, that is the first thing I would check. If you still have to manual, it should tell you how to check the lamps and which ones you need to order.
These should be special lamps only Panasonic sells. Therefore they might cost a few bills.
Posted on Feb 01, 2008
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
My samsung le40r7 tv dont turn on any more i bought it 3 years
Hi I am vortash .. there is a modification kit available for this tv and available from ebay priced about $50 0r £30 depending on your location . It is the start up driver circuit that needs these components on the power supply if you are competant to attempt this .However if not then I suggest that you take it to a local enginner for a free estimate he will at least be able to tell you the fault . regards Vortash
Mar 30, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Bought it a week ago today. now it mysteriiously
It sounds like it may have an bad solder connection in the power supply. Or It may have bad componets in the power supply. I would even try to take the battery's out of the remote just in case it is cause it to turn on/off.
Feb 25, 2010 | LG 47LH3000 LCD TV
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
Strange buzzing sound
Hi there! If it is an anoying sound I would personally have it checked if still under warranty. It may be a bad coil or transformer in the power supply. Enjoy what you paid for rather than sitting with a fault that might cost you extra later on. Best Wishes and Good Luck, JUS004
Aug 22, 2009 | Televison & Video
Samsung TV Won't Turn Off
if this set has a power relay the contacts in the relay are welded closed; unplug set for 10 seconds and plug back in; it will probably come streight on if relay is stuck. replacing relay will fix if this is the case
Apr 29, 2008 | Samsung TX-R2435 TV
Unable to get HDMI signal into TV
In the setup guide, try going to the HDMI option where you turn the montior out to "on" for the HDMI output. I don't believe that the receiver comes with the HDMI out already turned on...
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Televison & Video Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
