Question about LG WFT1071TP Top Load Washer
Washing machine how install washing machine timer spring
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^&%$
Posted on Oct 01, 2010
2 Suggested Answers
  • 1891 Answers
SOURCE: maytag top load washing machine model LAT9306AGE..
the timer on all maytag's ( top load turn clock wise/ push in to stop/ pull to start . the spring back ??? the timer shaft may be sticking and is hard to turn . remove face cap and clip pull dial and lube with a light oil or spray lube / reinstall and this moy help .. mm
Posted on Dec 02, 2009
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
The timer keeps buzzing
Spring in timer is defective...replace the timer!
Dec 26, 2012 | Kenmore 98702 Stacked Washer/Dryer
Hello. I have a GE Potscrubber 600 dishwasher. The soap dispenser will not close. This seems to be a common problem. Any help would be great, thank you.
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Oct 24, 2010 | GE Dishwashers
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Maytag top load washing machine model LAT9306AGE.. the timer doesn't spring back out when needed to during cycles
Dec 02, 2009 | Washing Machines
Maytag A408 washer- needthetimer part off for new
look at the link: http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153000&brandID=...
pop the front chrome cover off the knob, slide the spring clip off the timer shaft, remove the spring and bezel, then remove the dial indicator. Reverse this process to reinstall the knob.
Nov 18, 2009 | Maytag Performa PAV2200
MY KELVINATOR KL15TL WASHING MACHINE DOES NOT START THE SICLE AFTER LETTING IN THE WATER
I can think of three possible causes. The first is the timer not advancing to the wash cycle. Try manually advancing the timer and see if it will start. The second possibility is the drive motor or drive belt. Open the access panel to see if the belt is intact, then see if the motor starts when you manually advance the timer to wash. The third possibility is the lid switch. You can usually get to it by inserting a putty knife in the two from corners to pop the spring clips open, and the top flips back.
Aug 20, 2009 | Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
LG WFT1071TP Top Load Washer Logo
76 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
