Question about Refrigerators
Refrigerator body get warm
The refrigerator get warm at front of middle wall and left side at bottom ,Plaese HELP
  • 1,543 Answers
Many refrigerators use the waste heat extracted from the inside of the refrigerator to warm these areas in order to prevent condensation from occurring there. It is more efficient than using an electrical strip heater to do the same thing. This is perfectly normal.
Posted on Oct 21, 2008
Tip
How to get help so you can fix you own appliance
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your model number is needed in order for someone to help with the diagnosis or your appliance. There are lots of different parts and each model is different. Post this number in the description of your problem and you'll be much more likely to receive the help you need .
It's usually stamped on a small tag in a visible location on your appliance.
On your refrigerator look
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
On your oven look Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} on the back side of the door at the bottom or edge. On the vent trim behind the center of the door.
Washer-Dryer
behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Dishwasher-
Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Microwave-
on the face frame behind the door or on the back.
on Jan 31, 2010 | Dishwashers
How do I figure out my model number if I lost the owners manual and I need to get a new bottom tray on the door that holds all of the milk and OJ?
should be a sticker on the inside of the fresh food side (refrigerator side) i have a samsung and mine is when you open the door on the left wall up front... some are on right wall and some are actually on ceiling of refrigerator wall.... this should be all you need and then get on line and typre in samsung refrigerator parts a list of appliance parts dealers will come up.....good luck to you
Jan 03, 2011 | Samsung RB2155SH Bottom Freezer...
Refrigerator side warm bur appears freezer still
the freezer feeds cold air to the fridge side,there's an evaperator fan that just blows the cold air from the freezer to the refrigerator side and then it returns to the freezer through the air ducts.check this,when you open the freezer door do you hear the fan blowing in there?if you don't you have a bad evap fan motor,if you hear it,remove the second draw from the bottom in the freezer side and touch the back wall,if there's ice or like snow on the back wall you have a defrost problem.if this is it send me the model number and i can look up the parts in your machine and i can help you,also look to see if there's droplets and ice on the food and shelves in the freezer,somebody could have left the door open and the air ducts frooze up and the air can't blow from one side to the other,let me know what you find and i'll help you out
Jul 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The divider wall between the fridge and freezer stays very hot to the touch. Possibly the defrost mechanism is stuck??? Any ideas?
Check the fan which cools the compressor . Sometimes something gets caught in the blade . Also check that the coils at the front bottom are clean . If the motor is not turning and nothing obstructing the fan blade , replace the motor ( condensor motor )
Jun 16, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
