Question about Hitachi 43FDX01B TV
43fdx01 hitachi hello guys; ive got a 43fdx01b that i changed the convergence ic's on about a year ago. today its back in with a no start. found all the fault led's on in deflection board and on the power supply board.there are no fuses blown on any of the two boards. i would like to know where i need to start looking for this short. it seem that the h.o.t are ok and theres no discolored resistors around the convergence ic's. please respond bigpappy83@hotmail.com or here at fixya.com. thanx guys
  • howie spence Jul 19, 2006
    hello guys i really need some help on this 43fdx01b set cant really begin after changing stk392-110 ive still got a short. all fault led's are on and horizontal out is good and reg ck out ok. also found no shorted bridge rectifiers set seems to be pulsing for startup.
  • 979 Answers
Possible convergence overdrive from the IC's. This will cause the symptom you describe. ....accordianman
Posted on Oct 20, 2007
Hitachi Model# 43FDX01B is doing a double image.
You have a convergence problem, you will need to change the convergence IC's STK392-110, there is also 12 6.8 1w resistors that need to be changed, there is also 2 fusilbe resistors that may be open. You can probably Google the IC's as a kit and find them all in one kit.
You can fix this yourself and save about $300-$400 in repair bills.
Feb 23, 2010 | Hitachi 43FDX01B TV
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Hitachi 42" TV
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Jun 19, 2008 | Hitachi 43FDX01B TV
Hitachi 43fdx01b chasiss dp05f
some times convergence IC's coused to put set in shutdown unloading the three convergence connectors and trying to turn on the tv if the set turn on the problem is convergence IC's if not check voltage regulator ...if still having problems e-mail me
Mar 18, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B (convergence) problem
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Re: 43FDX01B blue convergence issues
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
Jan 02, 2008 | Hitachi 43FDX01B TV
Hdtv convergence problem on Hitachi
Needs convergence IC's replaced by qualified technician.
Good set to keep a few more years..................T.
Please rate this solution....................
Oct 24, 2007 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
108 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
