Will not turn on no power going to on off switch. fuse is ok
    Sergeant:
    Champion:
  • 227 Answers
Cay you give me the brand and the model number? thanks
caypianan@yahoo.com
Posted on Oct 21, 2008
1988 chevy 1500 everythingworks exept brake light turn signal ok tailghts ok no brake lights
Since the turns work in the back, that means the brake bulbs are good. Brake lights and turn signal lights share the same filament in the bulb.
There is a fuse for the brake lights. Then, there is a brake light switch on the brake pedal. You need a voltmeter or test light, after checking that fuse is good. Need to check if fuse has power on it. This is one of those fuses that are hot at all times-as long as battery is connected, voltage should be going through the fuse and up to the brake light switch. Check for power both places. The switch on the pedal is a simple on-off switch. When brake is depressed, the spring loaded switch is turned on-passing power on towards the brake lights.
But then the brake wire goes into the turn signal switch before going on to the brake bulbs...however, since your turns work good, I doubt if there is a problem in the turn switch. First check if the brake light switch is sending power on when switch is on.
Let me know what you find. Good luck.
Nov 27, 2013 | 2000 Ford Focus
My break light fuse keeps blowing in my 97 suburban any ideas why
Assuming it's a K1500, 15A STOP/HAZ fuse 1 in the instrument panel fuse block is the source of power. If the stop lamp switch checks OK, and the center high mount stop lamp is OK, the cruise control system gets input at this point and may be defective. Fuse 1 also feeds power through the turn/hazard switch to the stop filaments of the tail/stop/turn lamps and these presumably are OK
Sep 22, 2012 | 1997 Chevrolet Suburban
I have a 97 Valkyrie when I turn the ignition switch on I get no headlight and no power to starter button. Tested fuses all test ok when I turn the switch on I get power to sub fuses but no power on one...
Check the connections in starter relay fitting at top. They have been known to overheat and melt, if not just corroded by chance. This is between battery positive and power to headlight bucket (where most lights and ignition comes out of), and would explain why ALL lights and starter are dead when key is turned on. The relay is behind right side panel near other fuses, but has heavy battery cable coming in and going out of it.
Jul 12, 2012 | Honda F6 C Valkyrie Motorcycles
What happens if a ignition cylinder goes bad
The problem is in your ignition switch if you can verify that power is going to the switch. If no power is going to the switch, you could have a maxi fuse blown, the fuse that sends power to the switch.
Oct 15, 2017 | Cars & Trucks
I have no brake lights. I checked at the fuse box under the hood and found it OK. Then I went to the foot peddle switch and found the switch OK but when I checked for power going into the switch none could...
Do you have turn signals ok?
Is your rear turn signal bolb the same one used for brakes?
Some turn signals are amber and some are red using the same bulb as the brakes. In that case the brake lights go through the turn signal switch.
But you would have power at the pedal switch.
No relay but there should be a fuse in the dash anel or under the hood if you have a battery box under the hood. Your owner manual will tell you where the fuses are and which one is hte brake. Usually a 15 amp.
Mar 21, 2011 | 1994 Honda Accord
Fan motor won;t turn on blower motor is ok fuses are ok relay is ok but i still have no power at the switch what am i missing
sounds like the wire from fuse box to switch is bad, a fuse completes a circuit or route the fuse takes power in on one side and sends power out the other, I've seen it many of times but cant confirm its your problem. but the power comes in and the power goes out and the fuse checks good but on the out side it is not making connection to the wire or connector on the back of fuse box. run a jumper wire from a positive power source to the positive in on the switch does it work is there a good ground to the motor
Jan 14, 2011 | 2004 Dodge Dakota
Turn signals and brake lights won't function
GET A GOOD FUSE TESTER, TEST EACH FUSE. THERE ARE 2 FUSEBOXES. ONE UNDER THE HOOD & ONE IN THE DASH. ALL FUSES CAN BE TESTED WHILE STILL IN PLACE. THERE ARE TEST POINTS FACING OUT. TURN ON IGNITION SWITCH FOR THIS TEST. POWER ON 1 SIDE, BAD FUSE POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE, SPARE FUSE.
IF ALL FUSES RELATED TO THIS PROBLEM TEST OK, CHECK OR REPLACE THE TURN/SIGNAL/HAZARD FLASHER, { LOCATED UNDER DASH, NEAR STEERING COLUMN, PROBABLY SQUARE & BLACK. IF THAT'S OK, IT WILL HAVE TO BE THE TURN SIGNAL/ HAZARD SWITCH. ALSO CALLED COMBINATION SWITCH. REMOVE THE PLASTIC HOUSING AROUND THE STEERING COLUMN UNDER THE STEERING WHEEL. IT LOOKS LIKE THE AIRBAG & A LOT OF SPECIALIZED TOOLS WILL BE NEEDED. YOU MAY HAVE TO EMPLOY A RELIABLE SHOP IF THE COMBINATION SWITCH IS THE PROBLEM
Jan 10, 2011 | 1996 Chevrolet Cavalier
Power turns on but nothing else turns on, just the display screen. is there an easy fix ie fuse or something?
CHECK BREAKER AT MAIN BOX , SHUT OFF BREAKER ALL THE WAY OFF AND BACK ON. IF YOU DO NOT HAVE BLOWER WHEN YOU TURN FAN SWITCH TO ON THEN YOU STIIL HAVE NO POWER TO UNIT . GO TO OUT SIDE UNIT ON GROUND AND PULL OUT DISCONNECT FUSES AND TEST THEM OUT OF FUSE HOLDER LIKE AUTO FUSES. IF UNIT IS ON ROOF SHOULD HAVE FUSES UP ON ROOF IN 6  X4 GRAY BOX. SHUT OFF BREAKER FIRST BEFORE FUSE TEST. IF FUSES OK AND BREAKER OK THAN YOU MIGHT HAVE BLOWN TRANSFORMER.
Apr 21, 2010 | Danby DAC9003D Air Conditioner
1997 chevy cavalier wont turn over when you turn the igintion switch i have replaced the battery it still wont start the car what could be the problem?
check all fuses to see if they are ok. next make sure power is going through ignition switch. make sure ground wire or negative wire to engine is ok. and check all wires carefully. if checking power from switch, turn key to on and see if it has 12 volts,
Apr 06, 2010 | 1997 Chevrolet Cavalier
Display is not turning on, nothing is working
hi alex. i hope i can help you? may i please ask . if you have a little multimeter. do a check off the fuse do a check if you have the correct fuse in if ok? do a connitunity check.to see if the mains cable is broken? if all is ok open up and do a voltage check to see if the machine is receiving power? also you may like to try the switch to see if its getting power.and if ok go to the other side of the switch if dead replace the switch
May 05, 2009 | Cuisinart DCC490SA Coffee Maker
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
