Question about Sony STR-DE605 Receiver
No sond from speakers but with headphone jack
I cant get the reciver to supply sound to the speakers but when I use the headphone jack I get sound.
Is this a fuse problem or something more involved?
    Problem Solver:
  • 13 Answers
There is no problem with the amplifier audio,check some resistors or disconections near the spkr terminals.
Posted on Oct 21, 2008
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
Speakers are woking but wen plug jack for head phones not but wen test on sond working
when a headphone is plugged into the earphone jack it SHOULD turn off the speakers as both are not meant to run at same time.
Jun 14, 2012 | Acer Aspire 5720 6497 Laptop
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
I have a pioneer VSX 920 receiver that thinks i have headphones pluged in. I have no sound from the speakers and when trying to go in speaker related settings it displays: PHONESIN on the receiver. If I...
I think I just fixed a unit with the same problem. I opened the cover and found where the wire from the headphone jack plugs into a board just beside the power supply transformer. When removed, the unit appeared to select speakers as the output. Since the headphones are never used by the owner, I simply left the headphone cable unplugged. Unfortunately, I didn't have speakers to test it with but the unit appeared to be working correctly.
Sep 07, 2011 | Pioneer SX-315
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
I am recieving weird sounds only noticable when speakers or especially headphones are connected to my audio jack. This includes static from downloads and moving my mouse.
do you have a wireless phone close by wireless phones are bad about making sound through your speakers whenever they recive or send information, also goto the advanced settings of your sound properties
Oct 26, 2009 | Dell Latitude D620 Notebook
Does this thing even have speakers..cant get any sound
It definitely has built in speakers:
Built in Speakers 2 x 3W speakers
It also has a headphone out jack. If you can't get sound, check and see if the headphone jack works. Does the volume control work? If they do your problem is with the speakers. They may be blown or just disconnected.
If you can't get sound through the headphone jack and you do have volume control but no sound, it probably a problem with the mainboard. It may need to be replaced.
Not really worth fixing in my opinion. I'd Just get some external speakers and connect them that way. Of course, if you are relying on a cable input, thats a bit harder and you would need some tuner or a DVD/VCR player with a tuner that has the standard RCA red and white audio output.
Aug 14, 2009 | Sceptre X19GV-HDTV 19 in. LCD TV
128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
